[GRASS-dev] [GRASS GIS] #1671: grass/script/setup.py errors
Reporter: artegion | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Python | Version: 6.4.2
Keywords: | Platform: All
      Cpu: Unspecified |
grass/script/setup.py needs a {{{os.pathsep}}} at this line
     ## os.environ['PATH'] += os.path.join(gisbase, 'lib') ##WRONG##
     os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'lib')
then $GISBASE/extralib and $GISBASE/msys/bin are missed in PATH (for
windows only)
     ## added for winGrass
     if sys.platform.startswith('win'):
'extralib')
'msys','bin')
of course we need
{{{import sys}}}
at the beginning
Another point ----
From outside Grass Gis we '''must''' define $GISBASE, $GISRC and add
$GISBASE/etc/python to sys.path BEFORE import anything from grass
(I did'nt find anything about this in Programmer's Manual)
os.environ['GISBASE'] =gisbase
grass_python_dir= os.path.join(gisbase, 'etc','python')
if os.path.isdir(os.path.join(grass_python_dir,'grass')):
     sys.path.append(grass_python_dir)
else:
     raise Exception('etc\python\grass module not found')
os.environ['GISRC']= 'junk'
from grass.script import setup
gisrc= setup.init(os.getenv('GISBASE'),gisdb,location,mapset)
os.remove(gisrc)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1671&gt;
Reporter: artegion | Owner: martinl
     Type: defect | Status: assigned
Keywords: setup | Platform: All
      Cpu: Unspecified |
Changes (by martinl):
* cc: grass-dev@… (added)
  * keywords: => setup
  * status: new => assigned
  * owner: grass-dev@… => martinl
Comment:
Suggested changes applied in r52000 (trunk) and r52001 (devbr6), Backport
for relbr64 requires some testing.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/1671#comment:1&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:1 martinl]:
os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'msys', 'bin')
This doesn't belong in GRASS 7.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1671#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: setup
  Platform: All | Cpu: Unspecified
  * status: assigned => closed
  * resolution: => fixed
Comment:
Replying to [comment:2 glynn]:
OK, removed in r53313. Closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1671#comment:3&gt;
Comment(by martinl):
Forgot to mention that the fix has been backported to relbr64 in r53314.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1671#comment:4&gt;
