#1675: Grass GIS wxPython startup error
Reporter: grruddy | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: wxGUI | Version: 6.4.2
Keywords: | Platform: Linux
Cpu: x86-64 |
Grass was installed with the following options:
./configure --prefix=$INSTALL \
--enable-64bit --with-cxx \
--with-mysql \
--with-motif \
--with-cairo --with-freetype --with-readline \
--with-x --enable-shared \
--with-fftw-includes=$FFTW/include \
--with-fftw-libs=$FFTW/lib \
--with-mysql-libs=/usr/lib64/mysql \
--with-mysql-includes=/usr/include/mysql \
--with-proj-includes=$PROJ/include \
--with-proj-libs=$PROJ/lib \
--with-proj-share=$PROJ/share \
--with-gdal=$GDAL/bin/gdal-config \
--with-geos=$GEOS/bin/geos-config \
--with-python=/usr/bin/python-config \
--with-wxwidgets=$WXWIDGETS/bin/wx-config \
--with-cairo-includes=$CAIRO/include/cairo \
--with-cairo-libs="$CAIRO/lib $CAIRO/lib/cairo
$pixman_LIBS" \
--with-cairo-ldflags="-lcairo -lpixman-1" \
--with-motif-includes=$LESSTIF/include \
--with-motif-libs=$LESSTIF/lib \
--with-freetype-libs=/usr/lib64 \
--with-freetype-includes="/usr/include/freetype2"
This install uses GCC-4.7.0 and a system packaged version of Python 2.6.6.
Because Python is system packaged, the GDAL and wxPython support is
appended to the PYTHONPATH environment variable and is not installed
directly in the site-packages directory for python2.6. The installation
went through without any issues, but now the following error occurs upon
startup:
(attachment)
Text only mode works as expected, but the graphical issue needs to be
fixed. Any help would be appreciated. Any additional information can be
provided as need be. Also, it should be noted that this same installation
was successful on a SLES 10 system ( this system is RHEL 6 ). The main
difference being the GCC version and the fact that wxPython was installed
directly to the site-packages of the SLES 10 Python installation.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1675>
