[GRASS-dev] [GRASS GIS] #1679: d.histogram fails to start
Reporter: JRadinger | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Display | Version: svn-develbranch6
Keywords: | Platform: MacOSX
      Cpu: Unspecified |
It is not possible to launch d.histogram in GRASS 6.5SVN (r52187) either
via the GUI command console or via right mouse click on the raster file on
my Mac OSX system. Following error is produced:
   File "/Applications/GRASS-6.5.app/Contents/MacOS/etc/wxpyt
hon/gui_core/prompt.py", line 1118, in OnKeyPressed
self._runCmd(self.GetCurLine()[0].strip())
hon/gui_core/prompt.py", line 607, in _runCmd
if cmdString[:2] == 'd.' and not self.parent.curr_page:
AttributeError
'GMConsole' object has no attribute 'curr_page'
Ticket URL: <http://trac.osgeo.org/grass/ticket/1679&gt;
Keywords: d.histogram | Platform: MacOSX
      Cpu: Unspecified |
Changes (by hamish):
* cc: r52187 (removed)
  * keywords: => d.histogram
Comment:
The d.* modules are not intended to be run from the GUI command console,
nor from the OSX desktop.
You need to start an xmon from the GRASS Terminal window's command prompt
(d.mon x0), then run it. Or start the histogram from the "analyze map"
button which is to the right of the right-most magnifying glass icon in
the Map Display GUI window.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1679#comment:1&gt;
      Cpu: Unspecified |
Comment(by JRadinger):
To get a histogram with right click onto the raster -> histogam was
working before I did the SVN update (I can't remember my old SVN version,
~ some months old), thats just why I asked...
To start the histogram with "analyse map" is working.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1679#comment:2&gt;
      Cpu: Unspecified |
Comment(by cmbarton):
the histogram function works from the menu button on the display window. I
just tested this in GRASS 6.5 compiled a few hours ago.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1679#comment:3&gt;
      Cpu: Unspecified |
Comment(by annakrat):
Histogram from the context menu should be working now. When you type it in
the command line, the error message is fixed, however a warning dialog
window appears saying that you can't do that because it's not yet
implemented.
Anna
Ticket URL: <https://trac.osgeo.org/grass/ticket/1679#comment:4&gt;
      Type: defect | Status: closed
Resolution: worksforme | Keywords: d.histogram
  Platform: MacOSX | Cpu: Unspecified
Changes (by jradinger):
  * status: new => closed
  * resolution: => worksforme
Comment:
Histogram from context menu is working now. Thanks
Ticket URL: <http://trac.osgeo.org/grass/ticket/1679#comment:5&gt;
Component: wxGUI | Version: svn-develbranch6
  * component: Display => wxGUI
Ticket URL: <https://trac.osgeo.org/grass/ticket/1679#comment:6&gt;
