#1681: WXGUI vector editing fails with python unicode error
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: Unspecified |
Steps to reproduce:
* Create a new GRASS vector data set;
* In "Attribute table" dialog choose "Manage table" and add a single text
attribute;
* Rightclick layer and choose "Start editing";
* Add a feature and fill text field with: "āšņļ";
* Click "Submit" and observe infamous unicode error in WXGUI console.
File "/home/maris/soft/grass_trunk/dist.x86_64-unknown-
linux-gnu/etc/gui/wxpython/dbmgr/dialogs.py", line 318, in
OnSubmit
for sql in self.GetSQLString(updateValues = True):
linux-gnu/etc/gui/wxpython/dbmgr/dialogs.py", line 241, in
GetSQLString
updatedValues.append("'" + str(newvalue) + "'")
UnicodeEncodeError
'ascii' codec can't encode characters in position 3-4:
ordinal not in range(128)
Cpu: Unspecified |
Comment(by mlennert):
I can confirm this bug.
Setting utf-8 in the GUI preferences Attribut tab, I can edit the
attribute table and add 'āšņļ', but even with that setting, I cannot edit
the attributes in the digitizer. I get the same error message as Maris.
I think it might be helpful to try to develop guidelines for developers on
how to handle non-ascii. Especially in the wxGUI this issue comes up very
often.
It is still an issue with current trunk. As it prevents users from
creating new vector data sets, I'm setting this as a blocker. Unless GRASS
7.0 ships without wxGUI, UnicodeEncodeError needs to be eliminated in it.
Replying to [comment:2 marisn]:
> Some reading for those, who have problems with strings in Python: http://blog.notdot.net/2010/07/Getting-unicode-right-in-Python
I attached a diff which solves some of the issues. I didn't commit it
because it's not complete (I don't have much time for it). So feel free to
improve it.
* keywords: => encoding
* platform: Linux => Unspecified
Comment:
Replying to [comment:3 annakrat]:
improve it.
I extended the diff and it seems to work somehow so I committed it in
r61897. Needs testing.
Replying to [comment:5 neteler]:
> Replying to [comment:4 annakrat]:
> Can this be backported?
It works for me in trunk at least. So I would say +1.
Replying to [comment:6 mlennert]:
in r61897. Needs testing.
Thanks for testing, backported in r62378. I will close it for now, however
encoding issues generally are not solved properly yet.
