[GRASS-dev] [GRASS GIS] #1682: incorrect output from v.voronoi
Reporter: MichaelP | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Vector | Version: 6.4.2
Keywords: v.voronoi | Platform: Linux
      Cpu: x86-64 |
v.voronoi is generating nonsensical data. At times it appears to be
generating correct output, but at other times, the data generated is
corrupted. The attached data set is one such data set that triggers it to
generate incorrect output.
The attached data set is a subset from a LiDAR point cloud in ascii
format. Nad83 UTM 15N.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1682&gt;
      Cpu: x86-64 |
Comment(by neteler):
Screenshot of output map which is partially wrong, added. Looks like
a sort problem?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1682#comment:1&gt;
      Cpu: x86-64 |
Comment(by marisn):
Replying to [comment:1 neteler]:
> a sort problem?
It looks too much like #957
Ticket URL: <http://trac.osgeo.org/grass/ticket/1682#comment:2&gt;
      Cpu: x86-64 |
Comment(by mmetz):
Replying to [comment:2 marisn]:
> > a sort problem?
Fixed in r57268.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1682#comment:3&gt;
Priority: major | Milestone: 6.4.4
      Cpu: x86-64 |
Changes (by neteler):
  * milestone: 6.4.3 => 6.4.4
Comment:
Replying to [comment:3 mmetz]:
> Fixed in r57268.
Backport of r57268 attached (for G65) - to be tested.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1682#comment:4&gt;
      Cpu: x86-64 |
A suggestion is welcome how to backport r57268.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1682#comment:5&gt;
      Cpu: x86-64 |
Comment(by mlennert):
Replying to [comment:5 neteler]:
AFAICT, backport has already happened in r57819 and r57820. Output looks
fine to me, now.
Can this be closed ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1682#comment:6&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.voronoi
  Platform: Linux | Cpu: x86-64
  * status: new => closed
  * resolution: => fixed
Comment:
Closed as fixed, reopen if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1682#comment:7&gt;
