[GRASS-dev] [GRASS GIS] #1683: error message v.add.col on MacOSX
Reporter: jradinger | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Database | Version: svn-develbranch6
Keywords: v.add.col | Platform: MacOSX
      Cpu: Unspecified |
When trying to add a new column (v.db.addcol map=basins@test columns=area
DOUBLE) following error message is produced. Anyway the column is created
and
there seems no problem with the database table. Just the error message:
/Applications/GRASS-6.5.app/Contents/MacOS/scripts/v.db.addc
ol: line 80: Radinger/Library/GRASS/6.5/Modules/bin=/Library
/GRASS/6.5/Modules/bin:/Users/Johannes:/Users/Johannes
Radinger/Documents/GRASS-GIS/Scripts: No such file or
directory
ol: line 80: Radinger/Documents/GRASS-
GIS/Scripts=/Users/Johannes Radinger/Desktop: No such file
or directory
Ticket URL: <http://trac.osgeo.org/grass/ticket/1683&gt;
      Cpu: Unspecified |
Description changed by neteler:
Old description:
and
directory
or directory
New description:
and
directory
or directory
Ticket URL: <http://trac.osgeo.org/grass/ticket/1683#comment:1&gt;
      Cpu: Unspecified |
Comment(by neteler):
For shell debugging, please change the first line of
/Applications/GRASS-6.5.app/Contents/MacOS/scripts/v.db.addcol
from
#!/bin/sh
to
#!/bin/sh -x
and run it again. Then post the relevant error part here, thanks.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1683#comment:2&gt;
      Cpu: Unspecified |
Comment(by JRadinger):
Here the shell output after running v.db.addcol in shell with changed
first line:
GRASS 6.5.svn (spearfish60):~ > v.db.addcol map=streams@test
columns="testcol DOUBLE"
+ '[' -z /Applications/GRASS-6.5.app/Contents/MacOS ']'
+ '[' map=streams@test '!=' @ARGS_PARSED@ ']'
++ basename /Applications/GRASS-6.5.app/Contents/MacOS/scripts/v.db.addcol
+ CMDLINE=v.db.addcol
+ for arg in '"$@"'
+ CMDLINE='v.db.addcol "map=streams@test"'
+ for arg in '"$@"'
+ CMDLINE='v.db.addcol "map=streams@test" "columns=testcol DOUBLE"'
+ export CMDLINE
+ exec g.parser
map=streams@test 'columns=testcol DOUBLE'
+ '[' @ARGS_PARSED@ '!=' @ARGS_PARSED@ ']'
+ PROG=v.db.addcol
++ which awk
+ '[' '!' -x /usr/bin/awk ']'
+ unset LC_ALL
+ LC_NUMERIC=C
+ export LC_NUMERIC
++ g.gisenv
+ eval 'GISDBASE='\''/Users/Johannes' 'Radinger/Documents/GRASS-GIS'\'';'
'LOCATION_NAME='\''spearfish60'\'';' 'MAPSET='\''test'\'';'
'ADDON_PATH='\''/Users/Johannes'
Radinger/Library/GRASS/6.5/Modules/bin:/Library/GRASS/6.5/Modules/bin:/Users/Johannes
'Radinger/Library/GRASS/6.5/Modules/bin:/Library/GRASS/6.5/Modules/bin:/Users/Johannes'\'';'
'Radinger/Library/GRASS/6.5/Modules/bin='\''/Library/GRASS/6.5/Modules/bin:/Users/Johannes:/Users/Johannes'
'Radinger/Documents/GRASS-GIS/Scripts'\'';' 'Radinger/Documents/GRASS-
GIS/Scripts='\''/Users/Johannes' 'Radinger/Desktop'\'';'
'MONITOR='\''x7'\'';' 'GRASS_GUI='\''wxpython'\'';'
++ GISDBASE='/Users/Johannes Radinger/Documents/GRASS-GIS'
++ LOCATION_NAME=spearfish60
++ MAPSET=test
++ ADDON_PATH='/Users/Johannes
'Radinger/Library/GRASS/6.5/Modules/bin=/Library/GRASS/6.5/Modules/bin:/Users/Johannes:/Users/Johannes
/Applications/GRASS-6.5.app/Contents/MacOS/scripts/v.db.addcol: line 80:
Radinger/Documents/GRASS-GIS/Scripts: No such file or directory
++ 'Radinger/Documents/GRASS-GIS/Scripts=/Users/Johannes Radinger/Desktop'
Radinger/Documents/GRASS-GIS/Scripts=/Users/Johannes Radinger/Desktop: No
++ MONITOR=x7
++ GRASS_GUI=wxpython
+ : /Applications/GRASS-6.5.app/Contents/MacOS /Users/Johannes
Radinger/Documents/GRASS-GIS spearfish60 test
++ g.findfile element=vector file=streams@test mapset=test
+ eval 'name='\''streams@test'\''' 'mapset='\''test'\'''
'fullname='\''streams@test'\''' 'file='\''/Users/Johannes'
'Radinger/Documents/GRASS-GIS/spearfish60/test/vector/streams'\'''
++ name=streams@test
++ mapset=test
++ fullname=streams@test
++ file='/Users/Johannes Radinger/Documents/GRASS-
+ '[' '!' '/Users/Johannes Radinger/Documents/GRASS-
GIS/spearfish60/test/vector/streams' ']'
++ v.db.connect streams@test -gl layer=1 'fs=|'
++ cut -f2 '-d|'
+ table=streams
+ '[' -z streams ']'
++ v.db.connect streams@test -gl 'fs=|' layer=1
++ cut -f4 '-d|'
+ database='/Users/Johannes Radinger/Documents/GRASS-
GIS/spearfish60/test/dbf/'
++ cut -f5 '-d|'
+ driver=dbf
++ echo 'testcol DOUBLE'
++ awk -F, '{print NF}'
+ colnum=1
+ n=1
+ '[' 1 -le 1 ']'
++ cut -d, -f1
+ col='testcol DOUBLE'
+ '[' -z 'testcol DOUBLE' ']'
+ db.execute 'database=/Users/Johannes Radinger/Documents/GRASS-
GIS/spearfish60/test/dbf/' driver=dbf
+ echo 'ALTER TABLE streams ADD COLUMN testcol DOUBLE'
+ '[' 0 -eq 1 ']'
++ expr 1 + 1
+ n=2
+ '[' 2 -le 1 ']'
+ v.support streams@test 'cmdhist=v.db.addcol "map=streams@test"
+ exit 0
Ticket URL: <http://trac.osgeo.org/grass/ticket/1683#comment:3&gt;
Priority: major | Milestone: 6.4.3
Keywords: v.add.col | Platform: All
      Cpu: Unspecified |
Changes (by neteler):
  * priority: normal => major
  * platform: MacOSX => All
  * milestone: 6.5.0 => 6.4.3
Comment:
The problem is the white space in the path not handled properly:
++ MAPSET=test
++ MONITOR=x7
--> ADDON_PATH is broken into two lines.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1683#comment:4&gt;
Component: Shell Scripts | Version: svn-develbranch6
Keywords: v.db.addcol | Platform: All
      Cpu: Unspecified |
Changes (by hamish):
  * keywords: v.add.col => v.db.addcol
  * component: Database => Shell Scripts
Comment:
The immediate culprit is `eval g.gisenv`,
The underlying fix is to not store the addon path as a GRASS variable,
store it as a shell environment variable -- and only a shell variable --
instead.
Remove it from the g.gisenv list with:
g.gisenv set="ADDON_PATH="
then v.db.addcol should be happy.
Trying to make it both a shell environment variable and a grass variable
is well intentioned, but blurring definitions so that things can be set
and read independently in multiple places using the same namespace is
ultimately going to create more problems than it solves. The main question
I think is if we need some other place besides .grass.bashrc to store this
sort of thing, to be sourced by the grass startup script. ? (currently for
grass6 it needs to be set in ~/.bashrc since .grass.bashrc is sourced
later in the startup script.
The GUI can modify its own running environment on the fly with
os.environ(); command line users who want to modify their environment
generally can, and indeed want to, take care of themselves.
cheers,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1683#comment:5&gt;
      Cpu: Unspecified |
Comment(by hamish):
n.b. the `eval g.gisenv` will still be problematic if the GISDBASE path
contains a space. In this case just the MAPSET name is needed, so `eval
g.gisenv MAPSET` avoids trouble, but quoting by g.gisenv is something we
should probably discuss.
(nonetheless, having GRASS_ADDON_PATH enviro var and ADDON_PATH grass var
is unfortunate)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1683#comment:6&gt;
      Cpu: Unspecified |
Comment(by hamish):
devbr6/scripts$ svngrep -r g.gisenv * | grep eval | cut -f1 -d: | uniq |
wc -l
37
v.db.addcol restricted to just eval'ing MAPSET in devbr6 r52299, but many
still to audit. :frowning:
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1683#comment:7&gt;
      Cpu: Unspecified |
Replying to [comment:5 hamish]:
instead.
Backported to 6.4.svn, too.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1683#comment:8&gt;
      Cpu: Unspecified |
Comment(by jradinger):
I tried again with the first example (streams@test). No problems occured.
Anyway another
mapset still produces error messages:
(Tue Aug 14 12:46:01 2012)
v.db.addcol map=sender_point@FIDIMO_Cele columns=testcol DOUBLE
/usr/local/grass-6.5.svn/scripts/v.db.addcol: 1: eval:
FIDIMO_Cele: not found
(Tue Aug 14 12:46:02 2012) Command finished (1 sec)
And here the extended output:
(Tue Aug 14 12:48:12 2012)
+ [ -z /usr/local/grass-6.5.svn ]
+ [ map=sender_point@FIDIMO_Cele != @ARGS_PARSED@ ]
+ basename /usr/local/grass-6.5.svn/scripts/v.db.addcol
+ CMDLINE=v.db.addcol "map=sender_point@FIDIMO_Cele"
+ export CMDLINE
+ exec g.parser /usr/local/grass-6.5.svn/scripts/v.db.addcol
+ [ @ARGS_PARSED@ != @ARGS_PARSED@ ]
+ PROG=v.db.addcol
+ which awk
+ [ ! -x /usr/bin/awk ]
+ unset LC_ALL
+ LC_NUMERIC=C
+ export LC_NUMERIC
+ g.gisenv get=MAPSET
+ eval FIDIMO_Cele
+ FIDIMO_Cele
+ g.findfile element=vector file=sender_point@FIDIMO_Cele
mapset=
+ eval name='sender_point@FIDIMO_Cele' mapset='FIDIMO_Cele'
fullname='sender_point@FIDIMO_Cele' file='/home/radinger/Doc
uments/GRASS_locations/Cele_location/FIDIMO_Cele/vector/send
er_point'
+ name=sender_point@FIDIMO_Cele mapset=FIDIMO_Cele
fullname=sender_point@FIDIMO_Cele file=/home/radinger/Docume
nts/GRASS_locations/Cele_location/FIDIMO_Cele/vector/sender_
point
+ [ ! /home/radinger/Documents/GRASS_locations/Cele_location
/FIDIMO_Cele/vector/sender_point ]
+ v.db.connect sender_point@FIDIMO_Cele -gl layer=1 fs=|
+ cut -f2 -d|
+ table=sender_point
+ [ -z sender_point ]
+ cut -f4 -d|
+ v.db.connect sender_point@FIDIMO_Cele -gl fs=| layer=1
+ database=/home/radinger/Documents/GRASS_locations/Cele_loc
ation/FIDIMO_Cele/sqlite.db
+ cut -f5 -d|
+ driver=sqlite
+ awk -F, {print NF}
+ echo testcol DOUBLE
+ colnum=1
+ n=1
+ [ 1 -le 1 ]
+ cut -d, -f1
+ col=testcol DOUBLE
+ [ -z testcol DOUBLE ]
+ db.execute database=/home/radinger/Documents/GRASS_locatio
ns/Cele_location/FIDIMO_Cele/sqlite.db driver=sqlite
+ echo ALTER TABLE sender_point ADD COLUMN testcol DOUBLE
+ [ 0 -eq 1 ]
+ expr 1 + 1
+ n=2
+ [ 2 -le 1 ]
+ v.support sender_point@FIDIMO_Cele cmdhist=v.db.addcol
"map=sender_point@FIDIMO_Cele" "columns=testcol DOUBLE"
+ exit 0
(Tue Aug 14 12:48:13 2012) Command finished (1 sec)
So far as I can see there is no whitespace in the mapset.
Tested on Ubuntu 12.04 with Grass6-devel r52671. This might
be related to ticket #1696.
/johannes
Ticket URL: <http://trac.osgeo.org/grass/ticket/1683#comment:9&gt;
#1683: error message v.db.addcol
      Cpu: Unspecified |
Ticket URL: <http://trac.osgeo.org/grass/ticket/1683#comment:10&gt;
Reporter: jradinger | Owner: hamish
     Type: defect | Status: assigned
      Cpu: Unspecified |
* cc: grass-dev@… (added)
  * owner: grass-dev@… => hamish
  * status: new => assigned
Comment:
(see comment:5)
what does `g.gisenv` by itself on the command line show?
does you mapset have a space in it? (AFAIU you should have gotten an error
when you tried)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1683#comment:11&gt;
      Cpu: Unspecified |
sorry for responding so late.
today I tried example again and found out that the error messages are
related
a messy gisenv. Here first the errors from v.db.addcol
v.db.addcol map="test@FIDIMO_Cele" columns="testcol DOUBLE"
adinger/U_Radinger/05_GRASS/GR=/home/radinger/U_Radinger/05_GRASS/GRASS_Scripts:
not found
adinger/05_GRASS/GRASS_Scripts=/home/radinger/U_Radinger/05_GRASS/FIDIMO/FIDIMO_Script/fidimo
for grass 6.x/r.fidimo: not found
/r.rdfilter=/home/radinger/U_Radinger/05_GRASS/FIDIMO/FIDIMO_Script/fidimo
GRASS 6.5.svn (Cele_location):~ >
So I also checked the output of g.gisenv from the command line which seems
somehow
wrong. I looks like the output for GRASS_SCRIPTS is "chopped up" and
messy, and I don't know how this could happen.
GRASS 6.5.svn (Cele_location):~ > g.gisenv
GISDBASE=/home/radinger/Documents/GRASS_locations
LOCATION_NAME=Cele_location
MAPSET=FIDIMO_Cele
ADDON_PATH=/home/radinger/.grass6/addons:/home/radinger/.grass6/addons:/home/radinger/.grass6/addons:/home/radinger/.grass6/addons:/home/radinger/.grass6/addons:/home/radinger/.grass6/addons:/home/r
ASS_Scripts=/home/radinger/U_R:/home/radinger/U_Radinger/05_GRASS/GRASS_Scripts/FIDIMO_testbed
GRASS_GUI=wxpython
How can I clean up my gisenv as I think that might solve the problem?
Whats the best way? My ADDON_PATH is extremely long and repeatedly the
same. Furthermore it seems there is a line break in gisenv dividing "r"
and "adinger...", which is causing the problem above.
I still don't know how this could happen as I never touched the
gisenv deliberately.
/j
Ticket URL: <http://trac.osgeo.org/grass/ticket/1683#comment:12&gt;
      Cpu: Unspecified |
And no, my mapset generally don't have any spaces in it, just to avoid
such problems
Ticket URL: <http://trac.osgeo.org/grass/ticket/1683#comment:13&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:12 jradinger]:
The repetitions in ADDON_PATH could be caused by a bug in g.extension. You
could try to manually edit `~/.grass7/rc`.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1683#comment:14&gt;
      Cpu: Unspecified |
Comment(by hamish):
ditto, better a late response than none :slight_smile:
> problem? Whats the best way? My ADDON_PATH is extremely long
> and repeatedly the same. Furthermore it seems there is a line
> break in gisenv dividing "r" and "adinger...", which is causing
> the problem above.
see comment:5.
MarkusM wrote:
> You could try to manually edit ~/.grass7/rc.
In GRASS 6 the file is ~/.grassrc6, and you should not be in a GRASS
session when you edit it.
I have had another attempt at making v.db.addcol more robust to external
g.gisenv problems in r55162,3. This report should stay open until the
other ~36 scripts that use `eval g.gisenv` but only really need one
variable from it have been checked/fixed. Spaces and other fun chars in
GISDBASE will make eval unhappy.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1683#comment:15&gt;
      Cpu: Unspecified |
Comment(by hamish):
> the problem above.
see comment:5.
Thank you and Markus M. for the instruction. I've cleaned my ~/.grassrc6 and
don't get any error messages anymore when i try to use v.db.addcol.
Johannes
Hamish
      Cpu: Unspecified |
Comment(by hamish):
scripts in devbr6 now updated with r55194:55226, but need testing before
backport to the stable branch.
AFAICT the only ones which will actually trigger run-time processing
errors (instead of just the occasional harmless message) on WinGrass w/
spaces in GISDBASE, are:
  * r.pack/unpack (already backported)
  * r.in.srtm
  * db.droptable
  * d.rast.leg (bug? try erode.index@spearfish)
  * r.in.wms
  * i.image.mosaic
  * v.in.garmin (doesn't need to be fixed for wingrass as dep req's UNIX)
so those should be tested & then backported for 6.4.3.
the rest can wait until after the freeze and go in for 6.4.4.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1683#comment:16&gt;
Priority: major | Milestone: 6.4.4
      Cpu: Unspecified |
  * milestone: 6.4.3 => 6.4.4
Comment:
non-harmless cases listed in comment:16 backported to relbr64 in r55725.
testing still welcomed.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1683#comment:17&gt;
      Cpu: Unspecified |
Replying to [comment:16 hamish]:
> before backport to the stable branch.
For the record: Apparently are all r55194:55226 changes present in relbr6,
so they will go into GRASS 6.4.4, nice.
Replying to [comment:17 hamish]:
No issues reported so far.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1683#comment:18&gt;
