#1686: v.mkgrid should offer breaks option for vertical lines too
Reporter: marisn | Owner: grass-dev@…
Component: Vector | Version: unspecified
Keywords: v.mkgrid | Platform: Unspecified
Cpu: Unspecified |
Comment(by lucadelu):
Replying to [comment:1 neteler]:
> Anyone able to extend the breaks to vertical lines in v.mkgrid?
Thanks...
I added breaks to vertical lines to v.mkgrid, please check the attached
patch.
In the screenshots you can see:
* red lines: old behavior of v.mkgrid
* blue lines: new behavior of v.mkgrid with default breaks value (3)
* green lines: new behavior of v.mkgrid with breaks value 30
Cpu: Unspecified |
Replying to [comment:2 lucadelu]:
patch.
Component: Vector | Version: svn-releasebranch70
Cpu: Unspecified |
Changes (by neteler):
* version: unspecified => svn-releasebranch70
Comment:
Tested -l ok, thanks for the fixes and improvements. See attached
screenshot of a
v.mkgrid result generated in EPSG 3035, then reprojected to Latlong EPSG
4326.
