[GRASS-dev] [GRASS GIS] #1687: i.atcorr return NULL values
Reporter: curvelo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Imagery | Version: 6.4.2
Keywords: | Platform: MSWindows Vista
      Cpu: x86-64 |
Hello, my name is Alexander.
I'm not able generate atmospherically corrected image from the band 3 of
TM / Landsat 5 using i.atcorr.
No error occurs during the process, however, the output image appears to
be invalid and all pixels are NULL value.
The input image is converted to the same band reflectance at the top of
the atmosphere. The conversion was made by the module r.mapcalc.
I'm using version 6.4.2 of the GRASS GIS and working through the graphical
interface.
My OS is Windows Vista Business SP2.
Attached I am sending the *. MTL and basic metadata of the raster output
i.atcorr (r.info).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1687&gt;
      Cpu: x86-64 |
Comment(by curvelo):
hi,
This was the command line used in the process: "i.atcorr -o
iimg=L5181040_04020111020_B30_TOA@bug_2 icnd=input_grass_6.txt
oimg=L5181040_04020111020_B30_TOA_iatcorr".
Thanks.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1687#comment:1&gt;
      Cpu: x86-64 |
Changes (by gisix):
* cc: gisix (added)
Comment:
i.atcor produces NULLs and strange output also for other sensors:
I can confirm this for RapidEye data:
Input Data: L3A RapidEye data without notable clouds and no blackfill.
Bands used: bed / green / blue
As RapidEye data comes in 16bit, the input data was initially rescaled to
8bit [0-255]. The results were unexpected: Only three category values:
Many zeroes and a few "1" and "2" values. This applied for all three
bands.
In a next attempt, the original 16bit data was fed into i.atcorr. The
results are described below. This was compared with a shifting (r.rescale)
of the 16 bit value ranges of all bands to start with the value "0"
[Example: original range: [4068-56975] (range: 52907) -> new range: [0 -
52907]]. The results from both kinds of input are similar:
**For the red band, a reasonable result was produced.**
Statistics of red band (digital numbers) [r.univar]:
n=49000000
null_cells=25249370
cells=74249370
min=1286
max=58603
range=57317
mean=4733.57011167347
mean_of_abs=4733.57011167347
stddev=1226.24474903503
variance=1503676.18453598
coeff_var=25.905283329616
sum=231944935472
** For the green band, a NULL layer was produced. **
Statistics of green band (digital numbers) [r.univar]:
n=49000000
null_cells=25249370
cells=74249370
min=2464
max=54248
range=51784
mean=5646.62104434694
mean_of_abs=5646.62104434694
stddev=986.535495533873
variance=973252.283948265
coeff_var=17.471253831024
sum=276684431173
** For the blue band, faulty values (looked like a binary image of the
original scene) were produced. **
Statistics of blue band (digital numbers) [r.univar]:
n=49000000
null_cells=25249370
cells=74249370
min=4068
max=56975
range=52907
mean=6479.12217332653
mean_of_abs=6479.12217332653
stddev=859.459951841108
variance=738671.408818719
coeff_var=13.2650678417419
sum=317476986493
Ticket URL: <http://trac.osgeo.org/grass/ticket/1687#comment:2&gt;
      Cpu: x86-64 |
Comment(by gisix):
Another update:
The same data sets as described in my previous comment were used
(Spearfish AOI, 2 L3A tiles, no blackfill).
The three bands red,green,blue were all processed by the controll files
applicable for RapidEye-red/green/blue (i.e. each band was processed three
times times, once with the control file intended for it, and also with the
to other control files).
Results:
Control File "Blue":
13
05 09 18.00 -103.79170986 44.53451932
2
1
30
-1.100
-1000
88
Output: Reasonable results for red and green band, blue band produces
stark black and white image.
Control File "Green":
13
2
1
30
-1.100
-1000
89
Result: All bands produce just NULL values.
Control File "Red":
13
2
1
30
-1.100
-1000
90
Result: All bands produce reasonable output.
Conclusion: There is an issue how the "green control" file controls the
processing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1687#comment:3&gt;
      Cpu: x86-64 |
Comment(by neteler):
For the record, see also #1320
Ticket URL: <http://trac.osgeo.org/grass/ticket/1687#comment:4&gt;
Keywords: i.atcorr | Platform: MSWindows Vista
      Cpu: x86-64 |
Changes (by hamish):
  * keywords: => i.atcorr
Ticket URL: <http://trac.osgeo.org/grass/ticket/1687#comment:5&gt;
