#1689: weird import with r.in.gdal
Reporter: madi | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Raster | Version: svn-releasebranch64
Keywords: r.in.gdal | Platform: Linux
Cpu: x86-64 |
I pointed this out already in ML, but in the same thread there were many
topics so that i better separate this one in a dedicated ticket.
I have generated a vrt file by this procedure
http://grass.osgeo.org/wiki/Large_raster_data_processing and imported it
into grass with the following commands:
r.in.gdal input="/forest/ASTER-GDEM/Dem_lzw/mosaic.vrt" output="mosaic"
and
r.external -r input="/forest/ASTER-GDEM/Dem_lzw/mosaic.vrt"
output="mosaic2"
Then, comparing mosaic and mosaic2, i get:
GRASS 6.4.3svn (ASTER_GDEM):~ > r.info map=mosaic
| Layer: mosaic Date: Tue Jul 17 17:57:31 2012
| Mapset: PERMANENT Login of Creator: leomarg
| DataBase: /forest/GRASS/grassdata
| Title: ( mosaic )
| Timestamp: none
| Type of Map: raster Number of Categories: 6518
| Data Type: CELL
| Rows: 140401
| Columns: 198001
| Total Cells: 27799538401
| Projection: Latitude-Longitude
| N: 72:00:00.5N S: 32:59:59.5N Res: 0:00:01
| E: 44:00:00.5E W: 11:00:00.5W Res: 0:00:01
| Range of data: min = -9999 max = 6518
| Data Description:
| generated by r.in.gdal
| Comments:
output="mosa\ |
| ic"
GRASS 6.4.3svn (ASTER_GDEM):~ > r.info map=mosaic2
| Layer: mosaic2 Date: Wed Jul 18 10:54:37 2012
| Title: ( mosaic2 )
| Timestamp: none
| Type of Map: raster Number of Categories: 0
| Data Type: CELL
| Rows: 140401
| Columns: 198001
| Data Description:
| generated by r.external
| Comments:
output="\ |
| mosaic2"
The problem is that with r.in.gdal, the map is shrinked, while the map
produced by r.external is correct. See the attached pictures.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1689>
