[GRASS-dev] [GRASS GIS] #1695: GRASSGIS does not launch
Reporter: TheloniusMonk | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Default | Version: 6.4.2
Keywords: launch | Platform: MSWindows 7
      Cpu: Unspecified |
I just installed GrassGIS (6.4.2.2; 6.4.2.1 and 6.4.1.1). If i try to
start the program I always receive the following error-messages:
g.dirseps.exe - Application Error
g.gisenv.exe - Application Error
clean_temp.exe - Application Error
python.exe - Application Error
Every error message comes with the following text:
"The application was unable to start correctly (0xc0000022). Click OK to
close the application."
I already treid to install it into a folder without spaces (D:/data/GRASS)
and installed the latest Microsoft NET framework package. But the problem
did not get fixed.
Best regards
Alex
Ticket URL: <http://trac.osgeo.org/grass/ticket/1695&gt;
      Cpu: Unspecified |
Comment(by marisn):
Please check also Your home folder for any non-latin letters (i.e.
C:\users\Māris would cause failure).
Also worth to check if Your antivirus software isn't messing with GRASS
during installation. Usually to install GRASS or QGIS I have to disable
Comodo antivirus and defence+ Just temporary disable antivirus software
and reinstall GRASS. Do not disable firewall, as GRASS installs just fine
with firewall running and disabling firewall might leave Your computer
vulnerable to network viruses.
Also check if there isn't more information in "advanced" part of error
message.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1695#comment:1&gt;
      Cpu: Unspecified |
Comment(by neteler):
Can you please try a more recent installer (see also the comment above)?
http://wingrass.fsv.cvut.cz/grass64/
Ticket URL: <http://trac.osgeo.org/grass/ticket/1695#comment:2&gt;
      Cpu: x86-64 |
Changes (by spdj):
  * cpu: Unspecified => x86-64
Comment:
Same here on Windows 7 (64bit!). Using the ProzessMonitor we found a
missing read access to a DLL.
Check access rules of:
  * windows/SysWOW64/msvcr71.dll
Ticket URL: <http://trac.osgeo.org/grass/ticket/1695#comment:3&gt;
Keywords: launch, wingrass | Platform: MSWindows 7
      Cpu: x86-64 |
Changes (by hamish):
  * keywords: launch => launch, wingrass
Comment:
Replying to [comment:3 spdj]:
> found a missing read access to a DLL.
could you explain the process of doing that?
see also #1428
yesterday when pressing esc-enter I got an application error with
set_data.exe when starting from the DOS command line startup icon on
Windows7, I'm not sure if that's related or something else. (grass seemed
to start ok after ack, anyway)
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1695#comment:4&gt;
      Cpu: x86-64 |
Could you try this update?
http://www.microsoft.com/en-us/download/details.aspx?id=30679
"Visual C++ Redistributable for Visual Studio 2012 Update 1"
Ticket URL: <http://trac.osgeo.org/grass/ticket/1695#comment:5&gt;
      Cpu: x86-64 |
See also: http://grasswiki.osgeo.org/wiki/WinGRASS_errors
Ticket URL: <http://trac.osgeo.org/grass/ticket/1695#comment:6&gt;
      Cpu: x86-64 |
Comment(by hamish):
It might be worth spending a bit of time with Dependency Walker exploring
to see which of python.exe or wx.dll or gdal.dll or ... is responsible for
the new msvr100 dependency.
dep. walker: http://grasswiki.osgeo.org/wiki/Bugs#Using_ldd
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1695#comment:7&gt;
#1695: WinGRASS does not launch
Component: Startup | Version: 6.4.2
      Cpu: x86-64 |
  * component: Default => Startup
Ticket URL: <https://trac.osgeo.org/grass/ticket/1695#comment:8&gt;
      Cpu: x86-64 |
Comment(by hamish):
[comment:2 neteler] asked:
ping?
it should be fixed now if you select the install "important microsoft
runtime libraries" button during installation.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1695#comment:9&gt;
      Cpu: x86-64 |
No feedback, assuming that the new install "important microsoft runtime
libraries" button helps.
Closing, feel free to reopen if the problem persists.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1695#comment:10&gt;
