#1696: Error message v.db.dropcol (Add-On Path)
Reporter: jradinger | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Shell Scripts | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: All |
when I try to drop a column from a table I get following error message
although the table is modified correctly:
(Tue Aug 14 12:47:30 2012)
v.db.dropcol map=sender_point@FIDIMO_Cele column=testcol
/usr/local/grass-6.5.svn/scripts/v.db.dropcol: 1: eval: adin
ger/05_GRASS/GRASS_Scripts=/home/radinger/U_Radinger/05_GRAS
S/FIDIMO/FIDIMO_Script/fidimo for grass 6.x/r.fidimo: not
found
/usr/local/grass-6.5.svn/scripts/v.db.dropcol: 1: eval: /r.r
dfilter=/home/radinger/U_Radinger/05_GRASS/FIDIMO/FIDIMO_Scr
ipt/fidimo for grass 6.x/r.fidimo: not found
(Tue Aug 14 12:47:31 2012) Command finished (1 sec)
and here an extended output with the -x flag:
(Tue Aug 14 13:00:50 2012)
+ [ -z /usr/local/grass-6.5.svn ]
+ [ map=sender_point@FIDIMO_Cele != @ARGS_PARSED@ ]
+ basename /usr/local/grass-6.5.svn/scripts/v.db.dropcol
+ CMDLINE=v.db.dropcol
+ CMDLINE=v.db.dropcol "map=sender_point@FIDIMO_Cele"
"column=testcol"
+ export CMDLINE
+ exec g.parser
+ [ @ARGS_PARSED@ != @ARGS_PARSED@ ]
+ PROG=v.db.dropcol
+ g.tempfile pid=10834
+ TEMPFILE=/home/radinger/Documents/GRASS_locations/Cele_loc
ation/FIDIMO_Cele/.tmp/grassgis/10834.0
+ [ 0 -ne 0 ]
+ [ -z /home/radinger/Documents/GRASS_locations/Cele_locatio
n/FIDIMO_Cele/.tmp/grassgis/10834.0 ]
+ trap exitprocedure 2 3 15
+ g.gisenv
+ eval GISDBASE='/home/radinger/Documents/GRASS_locations';
LOCATION_NAME='Cele_location'; MAPSET='FIDIMO_Cele'; ADDON_P
ATH='/home/radinger/.grass6/addons:/home/radinger/.grass6/ad
dons:/home/radinger/.grass6/addons:/home/radinger/.grass6/ad
dons:/home/radinger/U_Radinger/05_GRASS/GRASS_Scripts:/home/
radinger/U_R'; adinger/05_GRASS/GRASS_Scripts='/home/radinge
r/U_Radinger/05_GRASS/FIDIMO/FIDIMO_Script/fidimo for grass
6.x/r.fidimo'; /r.rdfilter='/home/radinger/U_Radinger/05_GRA
SS/FIDIMO/FIDIMO_Script/fidimo for grass 6.x/r.fidimo';
GRASS_GUI='wxpython';
+ GISDBASE=/home/radinger/Documents/GRASS_locations
+ LOCATION_NAME=Cele_location
+ MAPSET=FIDIMO_Cele
+ ADDON_PATH=/home/radinger/.grass6/addons:/home/radinger/.g
rass6/addons:/home/radinger/.grass6/addons:/home/radinger/.g
rass6/addons:/home/radinger/U_Radinger/05_GRASS/GRASS_Script
+ adinger/05_GRASS/GRASS_Scripts=/home/radinger/U_Radinger/0
5_GRASS/FIDIMO/FIDIMO_Script/fidimo for grass 6.x/r.fidimo
found
+ /r.rdfilter=/home/radinger/U_Radinger/05_GRASS/FIDIMO/FIDI
+ GRASS_GUI=wxpython
+ : /usr/local/grass-6.5.svn
/home/radinger/Documents/GRASS_locations Cele_location
FIDIMO_Cele
+ g.findfile element=vector file=sender_point@FIDIMO_Cele
mapset=FIDIMO_Cele
+ eval name='sender_point@FIDIMO_Cele' mapset='FIDIMO_Cele'
fullname='sender_point@FIDIMO_Cele' file='/home/radinger/Doc
uments/GRASS_locations/Cele_location/FIDIMO_Cele/vector/send
er_point'
+ name=sender_point@FIDIMO_Cele mapset=FIDIMO_Cele
fullname=sender_point@FIDIMO_Cele file=/home/radinger/Docume
nts/GRASS_locations/Cele_location/FIDIMO_Cele/vector/sender_
point
+ [ ! /home/radinger/Documents/GRASS_locations/Cele_location
/FIDIMO_Cele/vector/sender_point ]
+ v.db.connect map=sender_point@FIDIMO_Cele -gl layer=1 fs=|
+ cut -f2 -d|
+ table=sender_point
+ [ -z sender_point ]
+ cut -f3 -d|
+ v.db.connect -gl fs=| map=sender_point@FIDIMO_Cele layer=1
+ keycol=cat
+ cut -f4 -d|
+ database=/home/radinger/Documents/GRASS_locations/Cele_loc
ation/FIDIMO_Cele/sqlite.db
+ cut -f5 -d|
+ driver=sqlite
+ col=testcol
+ [ testcol = cat ]
+ cut -d| -f1,2
+ v.info --q -c map=sender_point@FIDIMO_Cele layer=1
+ grep |testcol$
+ [ 0 -ne 0 ]
+ [ sqlite = sqlite ]
+ grep -v |testcol$
+ cut -d| -f1,2
+ cut -d| -f1
+ cat /home/radinger/Documents/GRASS_locations/Cele_location
/FIDIMO_Cele/.tmp/grassgis/10834.0.coldesc
+ cut -d| -f2
+ paste -d /home/radinger/Documents/GRASS_locations/Cele_lo
cation/FIDIMO_Cele/.tmp/grassgis/10834.0.colnames /home/radi
nger/Documents/GRASS_locations/Cele_location/FIDIMO_Cele/.tm
p/grassgis/10834.0.coltypes
+ tr \n ,
+ sed s+,$++g
+ COLDEF=cat INTEGER,River TEXT,Station
TEXT,Station_fullname TEXT,X_LambII INTEGER,Y_LambII
INTEGER,X_Lamb93 INTEGER,Y_Lamb93 INTEGER,adj_X DOUBLE
PRECISION,adj_Y DOUBLE PRECISION,N INTEGER
+ sed s+,$++g
+ tr \n ,
+ COLNAMES=cat,River,Station,Station_fullname,X_LambII,Y_Lam
bII,X_Lamb93,Y_Lamb93,adj_X,adj_Y,N
+ echo BEGIN TRANSACTION;
CREATE TEMPORARY TABLE sender_point_backup(cat INTEGER,River
TEXT,Station TEXT,Station_fullname TEXT,X_LambII
INTEGER,Y_LambII INTEGER,X_Lamb93 INTEGER,Y_Lamb93
INTEGER,adj_X DOUBLE PRECISION,adj_Y DOUBLE PRECISION,N
INTEGER);
INSERT INTO sender_point_backup SELECT cat,River,Station,Sta
tion_fullname,X_LambII,Y_LambII,X_Lamb93,Y_Lamb93,adj_X,adj_
Y,N FROM sender_point;
DROP TABLE sender_point;
CREATE TABLE sender_point(cat INTEGER,River TEXT,Station
PRECISION,adj_Y DOUBLE PRECISION,N INTEGER);
INSERT INTO sender_point SELECT cat,River,Station,Station_fu
llname,X_LambII,Y_LambII,X_Lamb93,Y_Lamb93,adj_X,adj_Y,N
FROM sender_point_backup;
CREATE UNIQUE INDEX sender_point_cat ON sender_point ( cat
DROP TABLE sender_point_backup;
COMMIT;
+ db.execute input=/home/radinger/Documents/GRASS_locations/
Cele_location/FIDIMO_Cele/.tmp/grassgis/10834.0
+ [ 0 -eq 1 ]
+ cleanup
+ rm -f /home/radinger/Documents/GRASS_locations/Cele_locati
on/FIDIMO_Cele/.tmp/grassgis/10834.0 /home/radinger/Document
s/GRASS_locations/Cele_location/FIDIMO_Cele/.tmp/grassgis/10
834.0.coltypes /home/radinger/Documents/GRASS_locations/Cele
_location/FIDIMO_Cele/.tmp/grassgis/10834.0.colnames /home/r
adinger/Documents/GRASS_locations/Cele_location/FIDIMO_Cele/
+ v.support map=sender_point@FIDIMO_Cele
cmdhist=v.db.dropcol "map=sender_point@FIDIMO_Cele"
"column=testcol"
+ exit 0
(Tue Aug 14 13:00:52 2012) Command finished (1 sec)
This might be related to ticket #1683 and is caused by a whitespace in one
of the specified Add-On paths. This has been tested on Ubuntu 12.04 with
GRASS 6.5SVN r52671.
/johannes
Ticket URL: <http://trac.osgeo.org/grass/ticket/1696>
