#1703: wxGUI vector and raster querying
Reporter: wenzeslaus | Owner: grass-dev@…
Priority: major | Milestone: 7.0.0
Component: wxGUI | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
The current state of map querying in wxGUI is not sufficient and some
general solution (from user point of view) is needed.
Wider discussion is necessary but there are some known problems already.
Several inconsistencies and problems:
* different text formatting for vector and raster
* for vector map with db table dialog is displayed but for map without
only v.what output is printed
* vector attribute dialog is editable
* coordinates are displayed only sometimes
* for vector map with some layers with db table and some without, only
layers with are displayed
Highly related tickes:
* #251 Enhancements to vector querying
* #304 quering disables vector transparency
* #523 wxGUI: querying a vector map in edit mode does nothing
* #547 Raster query in wxGUI
* #951 Error querying rasters in wxgui
* #1402 Allow input coordinates to v.what to create a bounding rectangle
for querying
* #1469 wxgui vector query doesn't work for maps without attribute table
* #1522 dbm_base.py fails with multilayer maps
* #1606 attribute query tool reports "nothing found" when clicking on a
vector object
* #1607 attribute query fails to display text attribute values
* #1608 WXGUI attribute query might lead to accidental attribute data
editing
* #1609 WXGUI doesn't offer a supported encodings for "Attribute data
encoding" setting
Other related tickets:
* #281 query tool crashes when the user presses mouse buttons fast
* #650 No warning when querying grid layer
* #897 WinGrass: error with "Query vector map (edit mode)"
* #941 add a query coordiantes under current cursor position
* #1651 Map display Query Vector tool fails
Replying to [comment:3 martinl]:
> Recently reimplemented in trunk. Anything left?, could we closed this
ticket?
From me, everything is fulfilled. Only the last point was not tested
(''for vector map with some layers with db table and some without, only
layers with db table are displayed''). But this may be caused by v.what
behavior.
For further reference, here is the list of still open related tickets:
for querying
* #1824 wxGUI should offer a vector geometry query tool
* #1826 New d.mon doesn't allow querying (can be closed soon)
