[GRASS-dev] [GRASS GIS] #1706: wingrass: open attribute table fails
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: wxGUI | Version: svn-releasebranch64
Keywords: wingrass,db | Platform: MSWindows 7
      Cpu: x86-64 |
tested here with
osgeo4w-grass6.4.3svn-r52845
osgeo4w-grass6.5.5svn-r52844
osgeo4w-grass7.0svn-r52843
and the nc-sample dataset:
- load for example vector firestation to the map display
- click button to open attribute table or right click open attribute table
- error messages pops up (screenshot attached)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1706&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [ticket:1706 hellik]:
table
additional information:
- error message (translated from german): command "columns" is either
false or couldn't be found
- the attribute table opens, but there is no content in it
Ticket URL: <https://trac.osgeo.org/grass/ticket/1706#comment:1&gt;
      Cpu: x86-64 |
Comment(by neteler):
I tried with r52862 G6.4.svn on Linux in English and in German locale, no
such problem. However, the 'command "columns"' problem might have to do
with a potentially i18N tagging? I cannot trace the message in the .po
files, perhaps it comes from Windows itself? Because Google shows quite
some hits with
"der Befehl ist entweder falsch geschrieben oder konnte nicht gefunden
werden"
Ticket URL: <https://trac.osgeo.org/grass/ticket/1706#comment:2&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:2 neteler]:
switched in wingrass7 the language (Settings -> Preferences -> Appearance
-> Choose language (requires to save and GRASS restart): en), the error
remains.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1706#comment:3&gt;
      Cpu: x86-64 |
Comment(by annakrat):
This error is caused by changes for #1633 and more information is in the
discussion
[http://osgeo-org.1560.n6.nabble.com/winGRASS-6-4-svn-Attribute-manager-
not-opening-td4999639.html here]
Ticket URL: <http://trac.osgeo.org/grass/ticket/1706#comment:4&gt;
      Cpu: x86-64 |
I disabled the fs option (which was causing the problem) for Windows in
r53233. Please test if it is working again.
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1706#comment:5&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:5 annakrat]:
now it works again.
thanks
Ticket URL: <http://trac.osgeo.org/grass/ticket/1706#comment:6&gt;
      Cpu: x86-64 |
Changed in all branches (r53244, r53245). If you agree we can close this
ticket (and the new one #1738).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1706#comment:7&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass,db
  Platform: MSWindows 7 | Cpu: x86-64
Changes (by hellik):
  * status: new => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/1706#comment:8&gt;
