[GRASS-dev] [GRASS GIS] #1707: g.manual does not run html browser in background
Reporter: annakrat | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Default | Version: unspecified
Keywords: g.manual | Platform: Unspecified
      Cpu: Unspecified |
In grass 6 g.manual doesn't launch html browser in the background so it is
blocking the gui (or command line). In grass 7 it doesn't block anything.
In grass 7, python script calls os.execlp. In grass 6, bash script is
used. If I add '&' at the end of the command (in
scripts/g.manual/g.manual, line 91) like this:
"$GRASS_HTML_BROWSER" file://"$DOC_BASE/$1.html" &
it works for me (using Ubuntu). I guess this not solution for all
platforms?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1707&gt;
      Cpu: Unspecified |
Comment(by wenzeslaus):
Workaround implemented using
[http://docs.python.org/library/webbrowser.html webbrowser] from Standard
Python Library (only for start up page and location wizard, r52953).
System default web browser is started.
import webbrowser
webbrowser.open(filePath)
Alternatively for wxGUI it would be possible to use
[http://docs.wxwidgets.org/2.6.3/wx_miscellany.html#wxlaunchdefaultbrowser
wxLaunchDefaultBrowser].
Ticket URL: <http://trac.osgeo.org/grass/ticket/1707#comment:1&gt;
Component: Docs | Version: unspecified
Keywords: g.manual | Platform: All
      Cpu: All |
Changes (by hamish):
  * platform: Unspecified => All
  * component: Default => Docs
  * cpu: Unspecified => All
Comment:
We tried that in the past, but had to revert it as it failed for people
using a text based html browser like lynx or links.
search the ML for earlier discussion of the issue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1707#comment:2&gt;
Resolution: | Keywords: g.manual
       CPU: All | Platform: All
Comment (by neteler):
Is this still an issue in G6?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1707#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: g.manual
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:3 neteler]:
Quickly tested help from start up dialog, location wizard, main gui,
modeler - works ok.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1707#comment:4&gt;
