[GRASS-dev] [GRASS GIS] #171: d.vect: -c type=area doesn't draw boundary
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: d.vect |
'd.vect -c type=area' doesn't draw boundaries.
If you use type=area,boundary you get them, but IIUC "area" is an alias
for "centroid,boundary", so you shouldn't have to do that.
I am not sure if 'd.vect -a type=area' will or not.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/171&gt;
Resolution: | Keywords: d.vect
Comment (by hamish):
correction: it draws the boundaries, but uses the same color as the fill
when it should make the area color random and the line color respect
color=. e.g.:
  d.vect -c type=area fcolor=none
see the d.vect symbol drawing code for an example of using a primary and
secondary color in place of line= and fill=.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/171#comment:1&gt;
Comment (by neteler):
I assume that in darea() of d.vect/area.c some test is needed in
the loop therein to distinguish the various vector types while
looping over all vectors.
Ticket URL: <http://trac.osgeo.org/grass/ticket/171#comment:2&gt;
Comment (by neuba):
Hi I don't know it is the same issue but I can not draw any vector map
with d.vect when I use command like d.vect output=map1 i got this error
message: output <map1> exist. If I put an inexistant vector, I got: map
<map1> not found.
Thank you
Ticket URL: <http://trac.osgeo.org/grass/ticket/171#comment:3&gt;
Comment (by martinl):
Replying to [comment:3 neuba]:
<map1> not found.
There is no 'output' parameter
d.vect --help
d.vect output=x
Sorry, <output> is not a valid parameter
ERROR: Required parameter <map> not set:
     (Name of input vector map).
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/171#comment:4&gt;
with d.vect when I use command like d.vect output=map1 ...
IMPORTANT to all SVN users:
After the recent change in parser.c you need to RECOMPILE GRASS from
scratch.
I wanted to post this but forgot about it. So
make distclean
sh configure ...
make
to get the parameters right again.
@neuba: this is unrelated to this bug report.
Ticket URL: <http://trac.osgeo.org/grass/ticket/171#comment:5&gt;
scratch.
make distclean
sh configure ...
make
Might it be better to just assign explicit values to the G_OPT_*
constants, so that this issue doesn't occur whenever new constants are
added or removed?
A related, but distinct option is to make e.g. G_gisinit() check that
the library and module were compiled with the same version of gis.h,
I.e.:
include/gis.h:
  int G__gisinit(const char *, const char *);
  #define GIS_H_VERSION "$Revision$"
  #define G_gisint(pgm) G__gisinit(GIS_H_VERSION, (pgm))
lib/gis/gisinit.c:
  int G__gisinit(const char *version, const char *pgm)
    if (strcmp(version, GIS_H_VERSION) != 0)
      G_fatal_error(_("Incompatible library version for module"));
On Sat, May 24, 2008 at 11:10 AM, Glynn Clements
scratch.
make distclean
sh configure ...
make
added or removed?
I.e.:
include/gis.h:
lib/gis/gisinit.c:
Sounds like a very good suggestion to me. I got trapped by this
myself a couple of times in the past.
  Platform: Unspecified | Cpu: Unspecified
Changes (by mlennert):
  * platform: => Unspecified
  * cpu: => Unspecified
Comment:
Attached diff should fix the bug. I don't really understand why there was
a conditioning on the value of rgb in there. Looking through the code, I
don't think it is useful, but please test (notably with some of the flags,
such as table color and z-color).
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/171#comment:6&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: d.vect
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
Fixed in 6.4: devel_grass6 (r351819) and 6.4.0svn (r35182).
Ticket URL: <http://trac.osgeo.org/grass/ticket/171#comment:7&gt;
