#1714: r.terraflow does not compile
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.3
Component: Default | Version: svn-releasebranch64
Keywords: r.terraflow | Platform: Unspecified
Cpu: Unspecified |
In the latest update of 6.4.3 svn, r.terraflow does not compile, at least
on the Mac. Here is the error:
Michaels-MacBook-Air:r.terraflow cmbarton$ make
c++ -c -I/Users/Shared/grass_dev/grass64_rb/dist.x86_64-apple-
darwin12.1.0/include -arch i386 -isysroot /Developer/SDKs/MacOSX10.6.sdk
-DUSER=\"cmbarton\" -DNODATA_FIX -D_FILE_OFFSET_BITS=64
-DPACKAGE=\""grassmods"\" -DELEV_FLOAT main.cc -o OBJ.x86_64-apple-
darwin12.1.0/FLOAT/main.o
In file included from main.cc:39:
In file included from ./common.h:27:
In file included from /Users/Shared/grass_dev/grass64_rb/dist.x86_64
-apple-darwin12.1.0/include/grass/iostream/ami.h:39:
-apple-darwin12.1.0/include/grass/iostream/empq_impl.h:26:
-apple-darwin12.1.0/include/grass/iostream/empq.h:33:
darwin12.1.0/include/grass/iostream/embuffer.h:1123:56: error:
default arguments cannot be added to an out-of-line definition of a
member of a class template
long em_buffer<T,Key>::insert(AMI_STREAM<T>* str, long bos=0) {
-apple-darwin12.1.0/include/grass/iostream/empq.h:35:
darwin12.1.0/include/grass/iostream/minmaxheap.h:494:7: error:
reference to non-static member function must be called; did you mean
to call it with no
arguments?
if (size) {
main.cc:181:16: warning: format string is not a string literal
(potentially insecure)
[-Wformat-security]
G_fatal_error(_("Unable to create temp dir"));
darwin12.1.0/include/grass/glocale.h:10:16: note:
expanded from macro '_'
#define _(str) G_gettext(PACKAGE,(str))
main.cc:191:15: warning: format string is not a string literal
[-Wformat-security]
G_warning(_("The '-q' flag is superseded and will be removed "
main.cc:367:19: warning: format string is not a string literal
[-Wformat-security]
G_fatal_error(_("cannot read range"));
main.cc:389:19: warning: format string is not a string literal
[-Wformat-security]
G_fatal_error(_("cannot write colors"));
main.cc:407:19: warning: format string is not a string literal
[-Wformat-security]
main.cc:414:19: warning: format string is not a string literal
[-Wformat-security]
main.cc:434:44: warning: format specifies type 'int' but the argument has
type 'unsigned long'
[-Wformat]
G_message( "\t\t FILL: %s [%d elements, %dB each]",
%ld
main.cc:437:45: warning: format specifies type 'int' but the argument has
[-Wformat]
G_message( "\t\t FLOW: %s [%ld elements, %dB each]",
%ld
8 warnings and 2 errors generated.
make: *** [OBJ.x86_64-apple-darwin12.1.0/FLOAT/main.o] Error 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/1714>
