[GRASS-dev] [GRASS GIS] #1717: layer remove does not work on multiple selections
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
You can make multiple selections in the layer manager, but you can't DO
anything with multiple selections (like move or remove them). We should
either not permit multiple selections (I think it is a flag for the tree
control) or fix it so that you can do something with multiple selections.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1717&gt;
Component: wxGUI | Version: unspecified
Keywords: layer manager, multiselection | Platform: Unspecified
      Cpu: Unspecified |
Changes (by martinl):
  * keywords: => layer manager, multiselection
  * component: Default => wxGUI
Ticket URL: <http://trac.osgeo.org/grass/ticket/1717#comment:1&gt;
Just airing my opinion: it would be really, really, good if the second option would be possible, having the ability to do something (like delete) multiple selection. I would make working with layers that much easier.
       Cpu: Unspecified |
Priority: normal | Milestone: 6.4.4
Component: wxGUI | Version: svn-releasebranch64
      Cpu: Unspecified |
Changes (by neteler):
  * version: unspecified => svn-releasebranch64
  * type: defect => enhancement
  * milestone: 6.4.3 => 6.4.4
Comment:
On Sun, Sep 2, 2012 at 10:07 AM, Paulo van Breugel
delete)
I have the same wish. When working with many layers (e.g., after multi-
layer
import from GeoTIFF), this missing feature arises.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1717#comment:2&gt;
      Cpu: Unspecified |
Comment(by annakrat):
Are you sure you can't remove them? It's working for me. There are 3
enabled options - remove, zoom, set region.
I recently fixed layer selection in grass 7 (#1616), seems that nobody
tested yet... I'd like to backport it soon.
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1717#comment:3&gt;
      Cpu: Unspecified |
Comment(by cmbarton):
I tested this on GRASS 7 compiled yesterday. Removing, moving, and zooming
only affects one of the maps selected.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1717#comment:4&gt;
      Cpu: Unspecified |
Are we really talking about the same thing? For example when I select 2
layers and choose 'Set computational region from selected maps' this
command is executed (copied from command output):
g.region rast=elevation@PERMANENT,aspect@PERMANENT -p
So this is ok. Is it possible that it's not working on Mac? I agree that
it is not possible to move them by dragging.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1717#comment:5&gt;
I just compiled the latest build (revision 53062) (working on Ubuntu 12.04) and I can confirm it only works on one of the maps selected (as far as I know, it never has been possible to act on more then one layer?)
       Cpu: Unspecified |
  Michael
I was mostly concerned with the 'remove' function. But I just tried the 'Set computational region from selected maps' and it doesn't work for me either. It sets the region for the first map of the selected ones.
But I am running GRASS GIS 7 (on Ubuntu 12.04), so was this not changed for GRASS 7?
Paulo
       Cpu: Unspecified |
      Cpu: Unspecified |
Maybe the different behaviour comes from different version of wx. I have
quite old 2.8.10.1 which is working ok.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1717#comment:6&gt;
      Cpu: Unspecified |
Could you try r53064 in grass7?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1717#comment:7&gt;
Brilliant, it works (with GRASS 7, r53065)!! You made my day!
Paulo
       Cpu: Unspecified |
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: layer manager, multiselection
  Platform: Unspecified | Cpu: Unspecified
Changes (by annakrat):
  * status: new => closed
  * resolution: => fixed
Comment:
Fix confirmed in [http://lists.osgeo.org/pipermail/grass-
dev/2012-September/059815.html], backported in r53070 and r53071 together
with changes related to ticket #1616.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1717#comment:8&gt;
We are talking about the same thing. I put 3 maps in the layer manager,
select them all and click 'remove'. One is removed only. Click again and
it says that nothing is selected. Select 2 maps covering different
geographical areas and 'zoom to map'. It zooms to only one of the maps.
Create a group; select 3 maps and drag them to the group. Only one moves
to the group.
I am just getting around here in Arizona this morning and have to meet my
daughter for breakfast :slight_smile: because it is a holiday. I'll test once I get
back. Thanks much.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1717#comment:9&gt;
I can confirm that this DOES work in GRASS 7 now. Thanks much. One caveat,
however. If you select a raster and a vector and zoom to map(s), it will
only zoom to EITHER the raster OR the vector, not to the combined raster
and vector.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1717#comment:10&gt;
It seems to me that the problem is in g.region. What is g.region supposed
to do with both parameters rast and vect?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1717#comment:11&gt;
good question. I think g.region used to expand to fit all maps of any
types, but I haven't tried it recently by itself recently.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1717#comment:12&gt;
