[GRASS-dev] [GRASS GIS] #1719: GRASS 7 Monitor command line support
Reporter: annalisapg | Owner: grass-dev@…
     Type: defect | Status: new
Component: Display | Version: svn-trunk
Keywords: wxgui | Platform: Unspecified
      Cpu: Unspecified |
in order to definitely migrate to GRASS 7, for our work it would be
fundamental to have the same Monitor functionalities than GRASS 6.
Mainly:
  * zoom
  * query
  * speed of display (!)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1719&gt;
Component: wxGUI | Version: svn-trunk
Keywords: d.mon | Platform: Unspecified
      Cpu: Unspecified |
Changes (by martinl):
  * keywords: wxgui => d.mon
  * component: Display => wxGUI
Comment:
Have you tried?
d.mon wx0
There are still some unresolved issues (including rendering speed). Anyway
possible to use or at least to test.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1719#comment:1&gt;
Yes I tried it, but I found that, for example, the zoom doesn’t zoom region but display map…
2012/9/3 GRASS GIS <trac@osgeo.org>
Cpu: Unspecified |
  • keywords: wxgui => d.mon
  • component: Display => wxGUI
Comment:
Have you tried?
d.mon wx0
Ticket URL: <http://trac.osgeo.org/grass/ticket/1719#comment:1>
grass-dev mailing list
grass-dev@lists.osgeo.org
      Cpu: Unspecified |
Comment(by annalisapg):
Yes, I tried but I found that, if I zoom on a specific zone, the
computational region remains the same - I should use "set computational
region from display", but it seems a little more complicated and less
intuitive than the old Monitor
Ticket URL: <http://trac.osgeo.org/grass/ticket/1719#comment:2&gt;
      Cpu: Unspecified |
Changes (by cmbarton):
  * type: defect => enhancement
Comment:
The old monitor system was fine for Linux in some respects but a problem
for other platforms. Making GRASS much better cross-platform software
meant that the very old monitor display architecture had to be replaced.
However, there are equivalent--and more scriptable--tools for the same and
other functions in GRASS 7. In fact, GRASS 7 is much more scriptable than
the old xmonitor architecture. For scripts, a difference between setting a
region in one way and another is negligible. For interactive use,
separating the display zoom from the computational zoom has a number of
advantages, including making the display faster with large maps. But it
doesn't work like GRASS 5 or even 6.1 anymore. Personally, I'm happy about
that because there is a lot more interactive functionality than there used
to be (in early GRASS 5, there was no way to even export the display to a
graphics file) and scripting is more flexible and reliable. This is not a
defect. I'm not sure if it is an enhancement request, but improved speed
is an enhancement that is always appreciated
Ticket URL: <http://trac.osgeo.org/grass/ticket/1719#comment:3&gt;
      Cpu: Unspecified |
Changes (by hamish):
* cc: hamish (added)
Comment:
I'm with annalisapg on this one. There are some refinements to wx0 which
would help (top toolbar replaced by a right-click menu, status bar at the
bottom optional, make query tool functional, but most importantly make
display region invisible to the user and have it be responsive to
g.region/WIND).
fwiw, I keep a little script called 'x0' in my addons dir which does:
#!/bin/sh
if [ -z "$GISBASE" ] ; then
    echo "You need to be in GRASS to use this"
    exit 1
fi
export GRASS_WIDTH=720
export GRASS_HEIGHT=585
GR_MAJ_VER=`g.version | cut -f2 -d' ' | cut -f1 -d'.'`
if [ "$GR_MAJ_VER" = "7" ] ; then
    echo "# Run this:"
    echo "export GRASS_WIDTH=720 GRASS_HEIGHT=585"
    d.mon2 -b width=$GRASS_WIDTH height=$GRASS_HEIGHT
else
    d.mon start=x0
    d.mon sel=x0
fi
d.mon2(.py) is available in grass7 addons.
when you run it from trunk you get text printed to the terminal like:
# Run this:
GRASS_PNGFILE="/home/hamish/grassdata/nc_spm_08/grass7/.tmp/ocean6/5684.0.bmp"
GRASS_RENDER_IMMEDIATE=PNG
GRASS_PNG_MAPPED=TRUE
GRASS_PNG_READ=TRUE
export GRASS_PNGFILE GRASS_WIDTH GRASS_HEIGHT GRASS_RENDER_IMMEDIATE
GRASS_PNG_MAPPED GRASS_PNG_READ;
d.erase bgcolor=white;
wximgview
image="/home/hamish/grassdata/nc_spm_08/grass7/.tmp/ocean6/5684.0.bmp"
percent=10 &
which sets up wximgview with a cut and paste*. No access d.zoom, d.where,
or d.what, but it is responsive to g.region, d.rast, d.vect, and d.erase,
and fulfills my minimalistic wishes.
[*] or ximgview, wxpyimgview, qiv as per handler option of d.mon2.py
regards,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:4&gt;
      Cpu: Unspecified |
Comment(by cmbarton):
What it sounds like you are asking for is the development and maintenance
of a second, interactive display architecture that is quite different from
the existing one--in the window controls, the way you interact with it,
and the way in which images are rendered. This architecture needs to mimic
the behavior of a GRASS 5 display and run from a bash script rather than
from Python.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:5&gt;
      Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:4 hamish]:
g.region/WIND).
... devs feel free to contribute on developing better stand-alone wx
monitors (needs some refactoring of existing wxGUI code (package
`mapdisp`)) ...
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:6&gt;
      Cpu: Unspecified |
I'm sure you feel you have a need for this. Though it would help to know
why you need a different GUI than the existing one. But the issue that
concerns me is that currently, there are only a very few people who are
working on interfaces. Maintaining the 99,000 + lines of code in the GUI
is a full time job for the few people who are doing this, all on a
volunteer basis.
Working on a 2nd, different interface takes away from time available to
improve and maintain the main interface because there is only so much time
in the day in addition to the jobs we are paid to do, no matter how much
we love the volunteer work on this project.
So it would be great if annalisapg and other people who have a need for it
could take on the task of developing and maintaining a 2nd interface for
GRASS.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:7&gt;
      Cpu: Unspecified |
Comment(by wenzeslaus):
Even if we have people, time or money to develop another (simpler, faster)
version of GUI, I think that this would be wasting resources.
But I understand the pressure for second GUI. To my knowledge there are
several problems with the wxGUI which are difficult to over come:
  * it is in Python and simple loop is always slower in Python then in
C/C++
  * loading of dynamic (wxWidgets, wxPython) libs and modules always takes
some time, when you open display/GUI for the first time (when I'm opening
the second display it is much faster)
  * rendering to files and then displaying this files on screen is slower
than direct drawing of data to screen
About the last point, we are using rendering to files because
displaying/drawing of maps is done by modules, not library functions, and
moreover, it is not safe to call functions from GUI since they call
G_fatal() which calls exit(), right?
However, the situation is not so bad. Considering current state, the
rendering can be improved at least in two ways:
  * change the PPM files to something compressed (see
[http://lists.osgeo.org/pipermail/grass-dev/2012-August/059099.html ML])
  * use different rendering engine for (big) GUI and for (wx) monitors.
This engine could use library functions and can call exit() because it
would end only one monitor, not the whole GUI. But there are two problems.
The first is mirroring of display architecture provided by modules and the
second is maintenance of additional code (but this can be only minor issue
if it is well designed)
Then I got impression that there is some issue with PNG driver (if we want
to use it instead of PPM) and also that cairo driver could help but it is
not ready.
I haven't studied this monitor/display topic and I can be wrong, please
correct me if so.
However, I'm pretty sure that for some things mentioned above and for
enabling wxGUI functionality to wx monitors heavy GUI code refactoring is
necessary. The place to start is mapdisp package as martinl mentioned. I'm
very interested in this refactoring but currently I have no time for it.
But at least we can start to discuss it.
Considering GUI development, I think that GUI code refectoring is what we
should spend time with, not the second GUI. After refactoring we can get
some new features much more easily and also the maintenance can be easier.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:8&gt;
      Cpu: Unspecified |
Comment(by hamish):
There is no need for a second GUI. Just a minor tweak of what we already
have for a slightly more useful minimalistic display port.
And of course, to be done as a side project by those who feel the
particular need for it themselves, not asking anything of anybody else.
best,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:9&gt;
      Cpu: Unspecified |
Comment(by neteler):
The request is really about optimization, especially to get rid of the
file based
rendering approach and to write directly to the graphic card's memory (as
wxNVIZ
does IMHO).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:10&gt;
      Cpu: Unspecified |
So let's start brainstorming about rendering.
Currently used options:
  * wxGUI renders to uncompressed PPM and uses g.pnmcomp
   * Glynn suggested that composition should be done by wxGUI
([http://lists.osgeo.org/pipermail/grass-dev/2012-August/059188.html
link])
   * can PIL be used? (currently only Cartographic Composer preview depends
on it)
  * wxWidgets xganim reads a raster file directly and stores data in
wxImage
   * it is fast in C++ but to do the same in Python you have to use some
numpy magic to make it at least comparably fast (Anna can tell more)
   * G_fatal_error() and exit() are still here
   * in order to provide full drawing capabilities code from d.* modules
have to be moved to library
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:11&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:11 wenzeslaus]:
link])
depends on it)
Note that the cairo driver can render to an X Pixmap. These can then be
composited via g.cairocomp. Rendering and compositing may be hardware-
accelerated, and the resulting raster data will never leave video memory.
However:
  1. Requires X. I don't think that there's any equivalent on Windows. It
relies upon the fact that an X client can create resources (e.g. Pixmaps)
on the server which are retained after the program terminates.
  2. Requires that cairo was built with XRender support (although that's
almost certain on X; cairo was created largely to facilitate the use of
XRender).
  3. Can wxWidgets use an X Pixmap directly (i.e. without copying the
contents to client memory and back again)?
  4. Leaving "stale" images in the X server's memory is even worse than
leaving stale PPM files in the temp directory. Even keeping all of the
"live" images in the X server's memory may be an issue on some systems.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:12&gt;
      Cpu: Unspecified |
In attachment png_rendering_pil_composition.diff you can see some changes
which are necessary for rendering PNG (instead of PPM) and composing of
images in Python using PIL (instead of g.pnmcomp).
It is not completely working code. It is only experiment to see if this
can be faster.
The answer is no. I don't have any numbers but user experience is
completely the same.
Files are much smaller and there is one file less (thanks to composing in
Python) but during zooming/panning the most of the time is spent with disk
IO. (Tested on Ubuntu 10.04.)
But we can output binary data to stdout and read them in Python directly.
This would avoid disk IO. What do you think about using stdout instead of
a file in case of d.* modules?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:13&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:13 wenzeslaus]:
The downside of this is that the d.* command will take longer as it has to
compress the output file.
If desired, we could have a single file without the compression overhead
by using the PNG writer from lib/pngdriver, which allows the compression
level to be set via the GRASS_PNG_COMPRESSION environment variable.
> (thanks to composing in Python) but during zooming/panning the most of
the time is spent with disk IO. (Tested on Ubuntu 10.04.)
Zooming and panning require re-executing the d.* commands to generate new
images.
directly. This would avoid disk IO. What do you think about using stdout
instead of a file in case of d.* modules?
That requires either storing all layers in memory, regardless of whether
or not they are displayed, or re-generating layers if they are disabled
then re-enabled. It also eliminates the possibility of implementing a
decent caching mechanism (i.e. being able to undo zoom/pan operations by
re-using the previous images rather than having to re-generate them).
And using pipes may be slower than disk (if the Python side is using
select(), there will be a context switch for each pipe-buffer-size of
data).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:14&gt;
      Cpu: Unspecified |
Perhaps it would help to give a simple description of the display
workflow.
1. All rendering begins with GRASS display modules, d.*. The PNG driver is
set so that rendering is to temporary PNM files. It could also be to PNG
or Cairo with current GRASS 7 architecture. IMHO, this is the place of the
greatest slow down. The default setting of the PNG driver is to render
files produced by the display modules to the current screen resolution and
H/W ratio, using a combination of temporary display region and PNG driver
settings for H and W. This avoids a problem with the old xmon driver that
rendered to the current region only--fast for regions with few cells but
really slow for regions with lots of cells.
2. All rendered PPM files are sent to g.pnmcomp along with opacity values
for each layer. These are rendered into a composite PNM image with the H/W
values from the PNG driver settings. The PNM image is translated to a PNG.
3. The PNG is read by wxPython and rendered to a display context (DC)
canvas. It can be shifted and rescaled on the fly (though with impacts to
resolution) so that panning and zooming actions can happen visually while
any needed rerendering is done in the background
Overlays like scales and legends are done somewhat differently. They also
depend on relevant GRASS modules like d.barscale and d.legend, but they
render to PNG files and are not composited with g.pnmcomp. They are read
into a DC canvas individually so that each can be arranged on top of the
base composite map.
There are several possible places for speed up in this workflow
1. All GRASS layers could simply be rendered to PNG files and use wxPython
for compositing in the DC canvas. Glynn has suggested this and it has long
been considered a medium term goal. But it takes fairly substantial
rewriting of part of the display code. Not huge, but considerable work all
the same. This could skip running g.pnmcomp and g.pnmtopng. There are a
number of wxPython compositing tools that allow you to shift images on
screen, zoom, and add transparency.
2. A 'wxPython driver' could be developed that would dispense with
rendering to files that need to be read. We discussed this sometime back.
Glynn's opinion at the time was that this would not be significantly
faster than rendering to files. Moreover the files provide a way to
recover the display in case of a crash. Of course the temp files also can
get orphaned and left on disk if there is a crash.
3. Intermediate would be to have something like g.pnmcomp that works
directly with PNG files or at least outputs to a PNG file to save the PNM
to PNG translation. I'm not sure if using a compressed file format would
save anything because something somewhere has to compress and decompress
it, taking CPU time. Also there is the chance of loss of information,
though that is probably of little to no concern for a display that is
regularly refreshed.
4. The d.* modules simply take some time to render. I'm pretty sure that
this is what takes up the most time in displays, even with displaying to
screen resolution instead of region resolution. Perhaps these could be
sped up. Or perhaps the rendering and compositing could be done in GRASS
in a single step.
Hope this is helpful to thinking about this.
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:15&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:15 cmbarton]:
By what? g.pnmcomp outputs a PPM file.
g.pnmtopng?
How would this work?
in a single step.
In theory, the fastest solution should be to use the cairo driver with
output to X Pixmaps. The d.* modules generate output in video memory, and
may be hardware accelerated. Compositing occurs entirely in video memory,
and may be hardware accelerated. The main unknowns are how hard wxWidgets
makes this, and whether something similar can be achieved on other
platforms.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:16&gt;
      Cpu: Unspecified |
Replying to [comment:16 glynn]:
platforms.
In wxWidgets there is wxBitmap ([http://wxpython.org/docs/api/wx.Bitmap-
class.html wxPython], [http://docs.wxwidgets.org/2.8/wx_wxbitmap.html
wxWidgets]).
This class encapsulates the concept of a platform-dependent bitmap, either
monochrome or colour or colour with alpha channel support.
This wxBitmap can be directly drawn on some wx widget/window. This
operation is fast.
Can be wxBitmap used for what you are talking about? It is the same as X
Pixmap on linux?
But how would be this bitmap/pixmap transfered from d.* module to wxGUI
application?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:17&gt;
      Cpu: Unspecified |
By wx.Image. It is translated to a wx.Bitmap
> g.pnmtopng?
Wrong. I mentioned g.ppmtopng by mistake.
No idea. Just that wxPython can read a bitstream.
that this is what takes up the most time in displays, even with displaying
to screen resolution instead of region resolution. Perhaps these could be
in a single step.
platforms.
X is only reliably available on Linux. Not really an option for Windows or
Mac.
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/1719#comment:18&gt;
