[GRASS-dev] [GRASS GIS] #1720: r.viewshed doesn't compile in GRASS 7
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Component: Compiling | Version: svn-trunk
Keywords: r.viewshed | Platform: Unspecified
      Cpu: Unspecified |
i don't know exactly when this started, but it is recent.
Last login: Mon Sep 3 13:55:06 on ttys000
Michaels-MacBook-Air:~ cmbarton$ cd
/Users/Shared/grass_dev/grass70_dev/raster/r.viewshed
Michaels-MacBook-Air:r.viewshed cmbarton$ make
c++ -arch i386 -isysroot /Developer/SDKs/MacOSX10.6.sdk
-I/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-
darwin12.1.0/include -I/Users/Shared/grass_dev/grass70_dev/dist.x86_64
-apple-darwin12.1.0/include -D_FILE_OFFSET_BITS=64 -DUSER=\"cmbarton\"
-Wno-sign-compare -DPACKAGE=\""grassmods"\"
-apple-darwin12.1.0/include -o OBJ.x86_64-apple-darwin12.1.0/distribute.o
-c distribute.cpp
In file included from distribute.cpp:52:
In file included from /Users/Shared/grass_dev/grass70_dev/dist.x86_64
-apple-darwin12.1.0/include/grass/iostream/ami.h:56:
-apple-darwin12.1.0/include/grass/iostream/empq_impl.h:43:
-apple-darwin12.1.0/include/grass/iostream/empq.h:51:
darwin12.1.0/include/grass/iostream/embuffer.h:1140:56: error:
       default arguments cannot be added to an out-of-line definition of a
member
       of a class template
long em_buffer<T,Key>::insert(AMI_STREAM<T>* str, long bos=0) {
-apple-darwin12.1.0/include/grass/iostream/empq.h:53:
darwin12.1.0/include/grass/iostream/minmaxheap.h:512:7: error:
       reference to non-static member function must be called; did you mean
to
       call it with no arguments?
   if (size) {
distribute.cpp:89:15: warning: format string is not a string literal
       (potentially insecure) [-Wformat-security]
     G_message(_("Start distributed sweeping."));
darwin12.1.0/include/grass/glocale.h:10:16: note:
       expanded from macro '_'
#define _(str) G_gettext(PACKAGE,(str))
distribute.cpp:149:15: warning: format string is not a string literal
     G_message(_("Distribution sweeping done."));
2 warnings and 2 errors generated.
make: *** [OBJ.x86_64-apple-darwin12.1.0/distribute.o] Error 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/1720&gt;
      Cpu: Unspecified |
Comment(by glynn):
This is effectively a duplicate of #1714 (the issue is in the iostream
headers, not r.terraflow or r.viewshed).
It should be fixed by r53077.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1720#comment:1&gt;
      Cpu: Unspecified |
Comment(by cmbarton):
Thanks. I will test tonight. If this solves the problem, it also needs to
be backported to GRASS 6.x
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1720#comment:2&gt;
      Cpu: Unspecified |
This does seem to solve the r.viewshed problem, but does not fix
r.terraflow not compiling (#1714).
However, adding --with-CXX=/usr/bin/g++ to my configure string does seem
to fix the r.terraflow problem. This switches from using c++ to g++.
William Kyngesburye's suggestion.
Michaesl
Ticket URL: <http://trac.osgeo.org/grass/ticket/1720#comment:3&gt;
      Cpu: Unspecified |
I was wrong about adding --with-CXX=/usr/bin/g++ to my configure string.
That doesn't switch compilers in platform.make. I needed to hack platform
make and change it manually. Then r.terraflow compiles
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1720#comment:4&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:3 cmbarton]:
With r53077, the compilation cannot fail with the errors in #1714. It
could still fail for other reasons, but those would need to be stated.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1720#comment:5&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:4 cmbarton]:
A specific C++ compiler can be forced by setting the CXX environment
variable, e.g.
CXX=/usr/bin/g++ ./configure ...
Similarly, CC, CPPFLAGS, CFLAGS, CXXFLAGS, and LDFLAGS can be set via
environment variables; the configure script won't auto-detect the setting
if the environment variable exists.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1720#comment:6&gt;
      Cpu: Unspecified |
Thanks. That's what I've done. Both r.terraflow and r.viewshed compile
correctly now.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1720#comment:7&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.viewshed
  Platform: Unspecified | Cpu: Unspecified
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
Backported to 6.4 and 6.5 in r53094 and r53095.
Closing since it should be fixed on all branches and trunk. Reopen if
needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1720#comment:8&gt;
