#1723: G_OPT_DB_COLUMNS does not allow input of multiple column names
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
G_OPT_DB_COLUMNS (gis.h) is supposed to indicate multiple column names can
be entered into a field. But only single column names are actually
accepted. Check out v.out.ascii for an example. I'm not sure WHERE the
actual problem lies--in gis.h, in g.parser, in forms.py (no reference to
G_OPT_COLUMNS in the latter however), or somewhere else.
Wherever this is defined for the interface, G_OPT_M_DATATYPE could
probably be fixed too. It is supposed to bring up a list of GRASS
datatypes, but does nothing AFAICT.
Replying to [ticket:1723 cmbarton]:
can be entered into a field. But only single column names are actually
fixed in 'turek' in r55651.
This should be probably reported as separate ticket.
Component: wxGUI | Version: unspecified
Keywords: multiple columns | Platform: Unspecified
Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:1 martinl]:
What is the problem with this element? Check for eg. `g.list`, check boxes
seem to be fine.
Cpu: Unspecified |
Comment(by cmbarton):
I recompiled yesterday r55705. This still does not work. To test, try to
output firestations from the nc_08 demo dataset to an ASCII file using
v.out.ascii. The column tool shows an empty pulldown. The dropbox appears
but it is blank.
