[GRASS-dev] [GRASS GIS] #1728: r.slope.aspect: possible data type bug?
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Component: Raster | Version: svn-trunk
Keywords: r.slope.aspect | Platform: All
      Cpu: All |
I noticed what might be a bug in the r.slope.aspect code.
If output map type precision (CELL,FCELL,DCELL) is not given, the
data_type variable defaults to DCELL*. According to the code comments,
data_type should be wrt the input map, not the output map.
(* while the output map type defaults to FCELL)
If output map type is given, the data_type is set to the same. The
intention is a bit clearer in the legacy code, a just-now change to
today's trunk removed some old code around that.
should it be using Rast_map_type() instead? Which type should the allocs
called later with data_type be using?
applies to all branches.
a DCELL input map with prec=int specified on the command line does not
cause a segfault in my tests, but none the less the code seems a bit
muddled...
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1728&gt;
