#173: v.in.ogr: truncate cnames to first word
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: v.in.ogr |
If you (ahem) don't read the instructions properly and with v.in.ogr's
cnames= option provide column types with the new names it gets added into
the vector's dbln file as an extra word, corrupting it. (it writes "cat
integer" as the key column, but then after reads DB filename as the third
word in the dbln file, which is "integer" not $GISDBASE/...)
then you can't do much (even remove the vector) without fixing the dbln
file.
to protect against that...
v.in.ogr line 270:
ncnames = 0;
if ( cnames_opt->answers ) {
i = 0;
while ( cnames_opt->answers[i++] ) {
ncnames++;
in that loop add some sort of
strchrnul(cnames_opt->answers[i-1], ' ') = '\0';
to cut away all but the first word?
how to write that correctly?
Reporter: hamish | Owner: grass-dev@…
Component: Default | Version: unspecified
Keywords: v.in.ogr | Platform: Unspecified
Cpu: Unspecified |
Changes (by mmetz):
* platform: => Unspecified
* cpu: => Unspecified
Comment:
Replying to [ticket:173 hamish]:
file.
> v.in.ogr line 270:
ncnames = 0;
i = 0;
ncnames++;
Fixed in trunk r52812 by adding G_strip() followed by G_strchg(). Works
for me now. To be backported.
Replying to [comment:2 hamish]:
> Replying to [comment:1 mmetz]:
> > Works for me now. To be backported.
