[GRASS-dev] [GRASS GIS] #1745: proposal: make -a flag the default behaviour for g.region
Reporter: mlennert | Owner: grass-dev@…
Component: Default | Version: svn-trunk
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
In my experience, when working with raster, having a precise resolution is
the most important issue, while exact extension is less important. I often
use existing vector data or bounds coordinates to determine the extent,
but then have to use the -a flag to make sure that the desired resolution
is kept.
I would like to propose that in grass7, the behaviour is switched, i.e. to
make the -a flag (Align region to resolution) the default behaviour, and
"align to bounds" the option.
I know this is a fundamental change in a fundamental module, but it's been
itching for quite a while and I always find myself in difficulties having
to explain to students why GRASS' default behaviour is the way it is...
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1745&gt;
Keywords: g,region | Platform: Unspecified
      Cpu: Unspecified |
Changes (by hamish):
  * keywords: => g,region
Comment:
> I always find myself in difficulties having to explain to students
Consider importing a grid-referenced dataset from 3rd party enviro model
output:
`g.region n=100025 s=49975 w=69975 e=120025 res=50`
Using '-a' breaks that by rounding to `n=100050 s=49950 w=69950 e=120050`.
(take care, d.zoom in grass6 does -a by default)
(I don't know about anyone else, but I have to deal with this all the time
when importing various ocean model data)
That's not specifically to say preserving the bounds is more important
than preserving the resolution (we'd be trading nice round resolution for
ugly nsew bounds; one problem for another, pick your poison), just that
IMO by default GRASS should try to do the least-damaging thing (whatever
that may prove to be..) even if that pursuit of best-correctness means
adding an extra lesson to the admittedly steep learning curve.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1745#comment:1&gt;
      Type: enhancement | Status: closed
Resolution: wontfix | Keywords: g,region
  Platform: Unspecified | Cpu: Unspecified
Changes (by mlennert):
  * status: new => closed
  * resolution: => wontfix
Comment:
Replying to [comment:1 hamish]:
output:
time when importing various ocean model data)
Ok, just wasn't aware of such use cases. Closing this as won't fix.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1745#comment:2&gt;
