GDAL
September 27, 2012, 7:22am
1
#1746: Map Display Output Save Issue
Reporter: scorpionlegend92 | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Imagery | Version: 6.4.2
Keywords: Save Image | Platform: MSWindows 7
Cpu: Unspecified |
I have 6.4.2 version of Grass software. It does not save the map display
output in png format. When I select the save option, only "image
processing, please wait" dialogue box appears and no output is generated
in the form of image file.
I am using this software on Windows 7 OS.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1746> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
September 27, 2012, 7:46am
2
Cpu: Unspecified |
Comment(by neteler):
Please check in the "Command console" tab for error messages and post them
here.
Thanks.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1746#comment:1> ;
GDAL
September 27, 2012, 8:18am
3
Component: wxGUI | Version: 6.4.2
Keywords: Save Image, wingrass | Platform: MSWindows 7
Cpu: Unspecified |
Changes (by martinl):
* keywords: Save Image => Save Image, wingrass
* component: Imagery => wxGUI
Ticket URL: <http://trac.osgeo.org/grass/ticket/1746#comment:2> ;
GDAL
September 27, 2012, 6:53pm
4
Cpu: Unspecified |
Comment(by annakrat):
It is probably already fixed. Check the error message in this email
[http://lists.osgeo.org/pipermail/grass-dev/2012-August/059576.html\ ] if it
is the same problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1746#comment:3> ;
GDAL
September 28, 2012, 7:36am
5
Cpu: Unspecified |
Comment(by scorpionlegend92):
Yes. It is the same issue. Has this problem been fixed in the version
6.4.3 or in the same version. When 6.4.3 version will be released?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1746#comment:4> ;
GDAL
September 28, 2012, 7:37am
6
Cpu: Unspecified |
This Error Appears:
File "C:\Program Files\GRASS
6.4.2\etc\wxpython\gui_modules\mapdisp.py", line 1159, in
SaveToFile
width, height)
6.4.2\etc\wxpython\gui_modules\mapdisp_window.py", line 575,
in SaveToFile
dc = wx.BufferedPaintDC(self, ibuffer)
File "C:\Program Files\GRASS 6.4.2\Python27\lib\site-
packages\wx-2.8-msw-unicode\wx\_gdi.py", line 4990, in
__init__
_gdi_.BufferedPaintDC_swiginit(self,_gdi_.new_BufferedPaintD
C(*args, **kwargs))
wx._core
PyAssertionError
C++ assertion "wxAssertFailure" failed at
..\..\src\msw\dcclient.cpp(219) in wxPaintDC::wxPaintDC():
wxPaintDC may be created only in EVT_PAINT handler!
Ticket URL: <http://trac.osgeo.org/grass/ticket/1746#comment:5> ;
GDAL
September 28, 2012, 7:38am
7
Cpu: Unspecified |
How can I save images now if the above stated error has been fixed?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1746#comment:6> ;
GDAL
September 28, 2012, 7:41am
8
Cpu: Unspecified |
Replying to [comment:6 scorpionlegend92]:
You can download a pre-release (i.e. daily snapshot) here:
http://wingrass.fsv.cvut.cz/grass64/
Ticket URL: <http://trac.osgeo.org/grass/ticket/1746#comment:7> ;
GDAL
October 3, 2012, 10:55am
9
Type: defect | Status: closed
Resolution: fixed | Keywords: Save Image, wingrass
Platform: MSWindows 7 | Cpu: Unspecified
Changes (by scorpionlegend92):
* status: new => closed
* resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/1746#comment:8> ;
