[GRASS-dev] [GRASS GIS] #1753: Distance analysis
Reporter: scorpionlegend92 | Owner: grass-dev@…
     Type: task | Status: new
Priority: blocker | Milestone: 6.4.3
Component: Database | Version: 6.4.2
Keywords: Distance | Platform: MSWindows 7
      Cpu: x86-64 |
I have to make distance analysis in Grass software. Can anyone provide me
help in this regard how to use these command.; if possible, can anyone
contact me and give me a demo on how to execute the task.
My main objective of using Grass GIS is to determine the minimum distance
between one layer coordinates with other layer coordinates. I only have to
display minimum/closest links in the form of line between two layers.
Also,when grass displays the line, where does it store the information of
distance between the coordinates that are represented
  by the line.
Hope to have a quick response from your end.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1753&gt;
      Cpu: Unspecified |
Changes (by scorpionlegend92):
  * cpu: x86-64 => Unspecified
Ticket URL: <http://trac.osgeo.org/grass/ticket/1753#comment:1&gt;
      Type: task | Status: closed
Resolution: invalid | Keywords: Distance
  Platform: MSWindows 7 | Cpu: Unspecified
Changes (by mlennert):
  * status: new => closed
  * resolution: => invalid
Comment:
Replying to [ticket:1753 scorpionlegend92]:
> Hi,
me help in this regard how to use these command.; if possible, can anyone
distance between one layer coordinates with other layer coordinates. I
only have to display minimum/closest links in the form of line between two
layers.
of distance between the coordinates that are represented
> by the line.
Please don't use the bug tracker for calls for help. Use the grass-users
list for that. I'm closing this ticket.
Your question lacks some details about types of data, but I would think
that v.distance is your best bet.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1753#comment:2&gt;
