#1757: LD_SEARCH_FLAGS incorrect for NetBSD
Reporter: brook | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: | Platform: Other Unix
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:4 glynn]:
> Replying to [comment:3 mmetz]:
> > Replying to [comment:2 glynn]:
> > > 7.0 doesn't support any BSD systems yet. New platforms need to be
added by people who actually have access to (and preferably knowledge of)
the platform in question.
> > However, I do not get 7.0 compiled on NetBSD 6.0.1, the error is
ld: unrecognized option '-Wl,-rpath,/home/metz/src/grass-7.0.svn/dist.i386
-unknown-netbsdelf6.0.1/lib'
> Do NetBSD shared libraries support rpath? If not, the linker probably
won't accept the switch.
Yes, NetBSD shared libraries support rpath.
> Also, -rpath is bad, as it hard-codes library paths, overriding
LD_LIBRARY_PATH (and it will probably result in hard-coding the build
directory into the installed binaries). -rpath-link is preferable, as that
just sets the path for dependency checking without storing it in the
binary.
NetBSD is a bit difficult, I have to check. Some more insights from
working with NetBSD:
I think I discovered inconsistencies, if not errors, in the G7 Make
system: flags meant for cc are also passed to ld and vice versa, probably
because it is assumed that ld = cc. For example, linking flags for cc must
have the form
-Wl,-rpath,${LIB_RUNTIME_DIR}
the equivalent to ld, if ld != cc, is
-rpath ${LIB_RUNTIME_DIR}
But Shlib.make does
LDFLAGS += $(SHLIB_LDFLAGS)
even though LDFLAGS are meant for cc and SHLIB_LDFLAGS are meant for ld,
at least aclocal.m4 says so. Shlib.make might also need LD_SEARCH_FLAGS.
Grass.make does
LDFLAGS = $(LIBPATH) $(LINK_FLAGS) $(LD_SEARCH_FLAGS)
even though LDFLAGS are meant for cc and LD_SEARCH_FLAGS are meant for ld,
Ticket URL: <https://trac.osgeo.org/grass/ticket/1757#comment:5>
