[GRASS-dev] [GRASS GIS] #1759: Selecting maps in dropdown menu: slider to move up/down maps does not work
Reporter: pvanbosgeo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Default | Version: svn-trunk
Keywords: | Platform: Linux
      Cpu: x86-64 |
When running GRASS (6.4 or 7.0) under Ubuntu (11.10 and 12.04), the slider
to move up/down in the dropdown list of maps does not work. It does appear
(see attached screenshot), but when clicking on it it disappears.
This affects all screens with the option to select a layer (i.e., the gui
of almost all grass functions)
It is also not possible to move down or up the list with maps using the
keyboard arrow (should that be a feature request?). Thus, the only two
ways to select maps is by scrolling using the mouse wheel, or, when one
wants to select one map only, typing in the first letter(s) of the map
name.
Although specific to Ubuntu (I suspect), it does seriously affect the user
experience of these users (not to be overly dramatic, but to illustrate
the problem, I finally got to report this because I am getting RSI
problems due to too much use of the mouse wheel)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1759&gt;
Component: wxGUI | Version: svn-trunk
Keywords: map selection | Platform: Linux
      Cpu: x86-64 |
Changes (by annakrat):
  * keywords: => map selection
  * component: Default => wxGUI
Comment:
Replying to [ticket:1759 pvanbosgeo]:
slider to move up/down in the dropdown list of maps does not work. It does
appear (see attached screenshot), but when clicking on it it disappears.
Could you try the widget in wxpython demo (download
[http://downloads.sourceforge.net/wxpython/wxPython-demo-2.8.12.1.tar.bz2
here]), it's the ComboCtrl widget, look for TreeCtrl popup. If it works
for you, there is some problem in the wxGUI code. For me (Ubuntu 10.04) it
works fine.
name.
Related ticket #1251
Ticket URL: <http://trac.osgeo.org/grass/ticket/1759#comment:1&gt;
The TreeCtrl demo works. I can move up and down the folders with both the up and down keyboard key and the mouse (see screenshot for latter).
Ubuntu 10.04 does not have the Unity interface yet I believe. My assumption was the problem is related to this. However, as said, the TreeCtrl demo works.
Maybe the following information is of use? GRASS is compiled with Python 2.7.3 and wxPython 2.8.12.1 (the demo package is Python 2.8 I see). I have compiled GRASS (both 6.4.3 and 7.0 from source, Python and wxPython are the default installs on Ubuntu 12.04)
Paulo
Cpu: x86-64 |
  • keywords: => map selection
  • component: Default => wxGUI
Comment:
here]), it’s the ComboCtrl widget, look for TreeCtrl popup. If it works
works fine.
name.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1759#comment:1>
Sorry, the demo package is for wxPython, not Python… so that agrees with what I have on my system
On Sat, Oct 6, 2012 at 1:05 PM, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Paulo
Cpu: x86-64 |
Comment:
works fine.
name.
      Cpu: x86-64 |
Comment(by annakrat):
I tried wxpython demo with Ubuntu 12.04 and the problems are there too.
The only thing I can recommend you is to disable the overlay scrollbar
feature as described [http://askubuntu.com/questions/36448/is-there-a-way-
to-blacklist-an-individual-application-from-using-overlay-scrollb here],
then it is working correctly.
I have no idea why the arrows don't work at all. This widget is full of
bugs. Maybe we should use a different one, there is
[http://wxpython.org/docs/api/wx.lib.combotreebox-module.html
ComboTreeBox] which seems to have the same functionality and it is working
properly.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1759#comment:2&gt;
      Cpu: x86-64 |
Comment(by pvanbosgeo):
Brilliant, thanks a lot for pointing out these solutions! Hopefully this
can be fixed permanently, but I am already very happy with this temporary
solution.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1759#comment:3&gt;
      Type: defect | Status: closed
Resolution: wontfix | Keywords: map selection
  Platform: Linux | Cpu: x86-64
  * status: new => closed
  * resolution: => wontfix
Comment:
To avoid the problem the overlay scrollbar can be disabled before
launching GRASS by:
export LIBOVERLAY_SCROLLBAR=0
It is a problem of wxPython/wxWidgets and there is a workaround, so I will
close it.
Other described problems are already in #1251.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1759#comment:4&gt;
      Type: defect | Status: reopened
Resolution: | Keywords: map selection
Changes (by isaacullah):
  * status: closed => reopened
  * resolution: wontfix =>
Comment:
I know this is marked as "closed", but I do want to just chime in to say
that this a problem on ANY linux windowing system using overlay
scrollbars. That includes both Unity and Xfce, and perhaps several others.
Thus, anyone trying to use GRASS on these systems is going to run intot
this problem, and it is a BIG problem, as it renders GRASS basically
unuseable. This may be related to other, more deeper problems with GRASS
menus, but since there is such an easy, very non-invasive way to fix this
for most by adding the line:
to the grass startup script, why not just do that by default?
~Isaac
Ticket URL: <https://trac.osgeo.org/grass/ticket/1759#comment:5&gt;
Comment(by hamish):
see also #973 (duplicate?)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1759#comment:6&gt;
