[GRASS-dev] [GRASS GIS] #176: wxpython gui crashed while importing dxf
Reporter: brian | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone:
Component: default | Version: svn-trunk
Keywords: wxpython dxf gtk |
wxpython gui crashed while importing dxf. Crash occurs towards end of
process:
v.in.dxf -e -f input=/home/xxxx/dxf/bathymetry_msl.dxf
output=bathymetry_msl_7 --overwrite
Location epsg:32704
SVN Build 31507
Ubuntu Hardy
GRASS 7.0.svn (xxxx):~/dev/svn > g.gui wxpython &
[1] 18304
(svn:18307): Gtk-CRITICAL **: gtk_progress_set_percentage: assertion
`percentage >= 0 && percentage <= 1.0' failed
[1]+ Done g.gui wxpython
Here is the output from the same command completed in tcltk gui:
93115 primitives registered
Building areas: GRASS_INFO_PERCENT: 0
Attaching islands:
Attaching centroids:
0 areas built
0 isles built
Topology was built
Number of nodes : 93508
Number of primitives: 93115
Number of points : 11945
Number of lines : 788
Number of boundaries: 0
Number of centroids : 0
Number of faces : 80382
Number of areas : 0
Number of isles : 0
Can supply a test dxf file if needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/176&gt;
  Priority: major | Milestone: 6.4.0
Resolution: | Keywords: wxpython dxf gtk
Changes (by martinl):
  * milestone: => 6.4.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/176#comment:1&gt;
  Reporter: brian | Owner: martinl
      Type: defect | Status: assigned
Component: Python | Version: svn-trunk
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
  * component: default => Python
* cc: grass-dev@lists.osgeo.org (added)
Comment:
Hopefully fixed in trunk/devbr6, r31509, r31508. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/176#comment:2&gt;
Comment (by brian):
Confirm fix in build 31513.
Ticket URL: <http://trac.osgeo.org/grass/ticket/176#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wxpython dxf gtk
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/176#comment:4&gt;
