[GRASS-dev] [GRASS GIS] #1762: g.extension fails again
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
I just tried g.extension with GRASS 7 r53330 and got a weird error.
(Tue Oct 9 09:16:50 2012)
g.extension extension=g.copyall operation=add
Fetching <g.copyall> from GRASS-Addons SVN (be patient)...
Compiling...
ERROR: Variable 'LOCATION_NAME' not set
make: *** [g.copyall.tmp.html] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
(Tue Oct 9 09:16:53 2012) Command finished (2 sec)
But when I run g.gisenv...
GRASS 7.0.svn (nc_spm_08):~ > g.gisenv
MAPSET=spatialtech2012
GISDBASE=/Users/Shared/grassdata
LOCATION_NAME=nc_spm_08
GUI=wxpython
GRASS_GUI=wxpython
Any ideas? (don't know what "component" to list for this)
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1762&gt;
      Cpu: Unspecified |
Comment(by annakrat):
For me it's working just fine (on Ubuntu, latest revision).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1762#comment:1&gt;
Priority: major | Milestone: 6.4.3
Component: Addons | Version: svn-releasebranch64
Keywords: | Platform: MacOSX
      Cpu: OSX/Intel |
Changes (by cmbarton):
  * component: Default => Addons
  * priority: normal => major
  * platform: Unspecified => MacOSX
  * version: unspecified => svn-releasebranch64
  * milestone: 7.0.0 => 6.4.3
  * cpu: Unspecified => OSX/Intel
Comment:
I just tried g.extension for the first time in awhile in GRASS 6.4.3
release branch.
It is broken on the Mac at least. I've seen notices that it is broken on
Windows. This may be the same problem. But I'm assuming not for the
moment. Here the error. GRASS_ADDON_PATH is correct. The problem is
somewhere else. So far, I've tried r.xtent, r.out.kml, and r.prominence. I
KNOW that r.prominence used to compile under GRASS 6 at least in the past
couple years. g.extension has always been on the buggy side with the mac.
But it was working more or less the last time I tried it a year or so
back.
Here is the error for r.xtent
(Sun Feb 24 14:32:13 2013)
g.extension.py extension=r.xtent operation=add
WARNING: GRASS_ADDON_PATH has more items, using first defined -
'/Users/cmbarton/Library/GRASS/6.4/Modules/bin'
Fetching <r.xtent> from GRASS-Addons SVN (be patient)...
Compiling...
/Applications/GRASS/GRASS-6.4.app/Contents/MacOS/include/Mak
e/Grass.make:423: warning: overriding commands for target `/
Users/Shared/grassdata/Global_latlon/Spain_sites_SAA2012/.tm
p/Michaels-MacBook-Air.local/37744.0/r.xtent/bin'
e/Grass.make:414: warning: ignoring old commands for target
`/Users/Shared/grassdata/Global_latlon/Spain_sites_SAA2012/.
tmp/Michaels-MacBook-Air.local/37744.0/r.xtent/bin'
e/Module.make:25: warning: overriding commands for target
`install'
e/Rules.make:99: warning: ignoring old commands for target
`install'
at_exit_funcs.c:30:23: error: grass/gis.h: No such file or
directory
at_exit_funcs.c:31:27: error: grass/glocale.h: No such file
or directory
directory
or directory
lipo: can't figure out the architecture type of: /var/folder
s/65/pp9w7z0d1mj502pj8hhl7vfw0000gn/T//ccw30r7o.out
make: *** [OBJ.x86_64-apple-darwin12.2.0/at_exit_funcs.o]
Error 1
(Sun Feb 24 14:32:21 2013) Command finished (8 sec)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1762#comment:2&gt;
      Cpu: OSX/Intel |
Comment(by hellik):
Replying to [comment:2 cmbarton]:
>I've seen notices that it is broken on Windows. This may be the same
problem. But I'm assuming not for the moment.
in windows precompilded binaries/scripts are used.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1762#comment:3&gt;
      Cpu: OSX/Intel |
Comment(by cmbarton):
So apparently not related then.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1762#comment:4&gt;
#1762: g.extension fails again on Mac
      Cpu: OSX/Intel |
Comment(by hamish):
Was this the shell script version from the command line, or the python
version of g.extension from the wxGUI?
Does installing a shell or python script addon (as opposed to a compiled C
code one) work?
Is Xcode installed?
Do newer versions of Xcode include GNU make along with LLVM?
Does the current MacGrass package ship the $GISBASE/include/ headers &
matching paths in $GISBASE/include/Make/*.make?
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1762#comment:5&gt;
      Cpu: OSX/Intel |
Comment(by hamish):
see also #854
Ticket URL: <https://trac.osgeo.org/grass/ticket/1762#comment:6&gt;
      Type: defect | Status: closed
Resolution: duplicate | Keywords:
  Platform: MacOSX | Cpu: OSX/Intel
Changes (by hamish):
  * status: new => closed
  * resolution: => duplicate
Comment:
see questions in comment:5.
continued in #854.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1762#comment:7&gt;
