#1768: wingrass6.x: python addon scripts aren't working
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.4
Component: Addons | Version: svn-releasebranch64
Keywords: wingrass, python, addon | Platform: MSWindows 7
Cpu: x86-64 |
tested with
System Info
GRASS version: 6.4.3svn
GRASS SVN Revision: 53519
GIS Library Revision: 50937 (2012-02-25)
GDAL/OGR: GDAL 1.9.2, released 2012/10/08
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.2
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
and the wxgui-g.extension manager
exe-addons are installed here (e.g.):
C:\Users\xxxxx\AppData\Roaming\GRASS6\addons
r.xtent.exe
shell addon scripts and their related bat-files are in the same folder
(e.g.):
v.rast.stats2
v.rast.stats2.bat
the content of the related bat (e.g. v.rast.stats2.bat) is:
@"%GRASS_SH%" "%GRASS_ADDON_PATH%/v.rast.stats2" %*
shell scripts are working now (see ticket #1692).
there are also some nice python scripts for grass6.x in the addons
python addon scripts (i.e.) are placed at the moment into:
r.basin.py
r.ipso.py
r.wf.py
but the related bat-files are in:
C:\Users\xxxxx\AppData\Roaming\GRASS6\addons\bin
r.basin.py.bat
r.ipso.py.bat
r.wf.py.bat
the content of the related bat-files (e.g. r.basin.py.bat) is:
@"%GRASS_SH%" "%GISBASE%/scripts/r.basin.py" %*
the nice python addons scripts aren't working in the moment.
following issues:
'''(1)''' should the content of the related bat-files be changed to?:
@"%GRASS_PYTHON%" "%GISBASE%/scripts/r.basin.py" %*
'''(2)''' should the related bat-files be renamed?
r.basin.py.bat => r.basin.bat
because python addon scripts can invoke another python addon script
(e.g.):
r.basin.py
grass.run_command('r.ipso', map = 'r_elevation_crop',
image = prefix, flags = 'ab')
'''(3)''' should the related bat-files be moved like shell script bat-
files?
from
to
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1768>
