[GRASS-dev] [GRASS GIS] #1775: v.surf.rst does not respect mask
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Component: Vector | Version: svn-trunk
Keywords: v.surf.rst | Platform: Unspecified
      Cpu: Unspecified |
When the mask argument is set in the v.surf.rst command, it gives an error
and does not produce an interpolated surface. The error is:
ERROR: Input window changed while maps are open for read
I have not checked to see if this affects 6.4.3 too
Ticket URL: <http://trac.osgeo.org/grass/ticket/1775&gt;
      Cpu: Unspecified |
Comment(by helena):
I can confirm this ERROR when mask parameter is given in GRASS7.
Also, the output of rescaled tension fi which used to be written out with
-t flag has disappeared.
I just checked in GRASS6.4.3 and mask there works as intended - user can
define it as parameter mask=
or by setting MASK for the current mapset.
Helena
Ticket URL: <http://trac.osgeo.org/grass/ticket/1775#comment:1&gt;
      Cpu: Unspecified |
Comment(by annakrat):
When you have a look at
[http://trac.osgeo.org/grass/browser/grass/trunk/lib/raster/set_window.c#L157
the code calling fatal error], there is some additional functionality
after G_fatal_error which is nonsense. Maybe there should be a warning
instead or the following line should be removed to avoid confusion.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1775#comment:2&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:2 annakrat]:
That was inadvertently left behind in r42876. Fixed in r53920.
The core issue is that v.surf.rst (or possibly the RST library itself)
needs to be updated to correctly handle a split window (different windows
for read and write). I updated most of the affected modules when the
change was introduced, but I didn't understand v.surf.rst well enough to
fix it.
GRASS 7 doesn't allow the window to be changed while maps are open.
Most of the modules which did this were resampling modules (r.resamp.*,
r.proj) which used one window for reading and one for writing, alternating
between the two for each row. This was highly inefficient, as changing the
window recalculates the column mapping for each open map.
So it was changed to have one window for reading and one for writing. Both
windows must be set before any maps are opened, and cannot be changed
thereafter. In order to catch any bugs, any incompatible or ambiguous
behaviour currently results in a fatal error.
One consequence of this change is that it isn't possible to read multiple
maps at different resolutions. If this turns out to be necessary,
lib/raster could be changed e.g. to allow a specific window to be set for
a specific map. But I don't want to do that unless it's strictly
necessary, as it introduces the potential for confusion. E.g. the number
of rows/columns for a given map will no longer match the result of
Rast_{input,output}_window_{rows,cols}, which in turn affects functions
such as Rast_allocate_*_buf and Rast_zero_*_buf.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1775#comment:3&gt;
      Cpu: Unspecified |
Comment(by helena):
Glynn, thanks for the explanation - there is no reason for v.surf.rst to
read/write multiple maps at different resolutions, I am guessing that it
tries to read the mask at its original resolution, but it should read it
at the same resolution as is set by g.region for output. I can try to look
at the code when time allows,
Helena
Ticket URL: <http://trac.osgeo.org/grass/ticket/1775#comment:4&gt;
Priority: major | Milestone: 7.0.0
      Cpu: Unspecified |
Changes (by bhlevca):
  * priority: normal => major
Comment:
I am curios what is the status of this.
Basically the current code does not allow to interpolate with a mask
because of the ERROR: Input window changed while maps are open for read.
I don't understand Glynn's explanation about multiple resolutions. I have
one mask and a vector layer and I want to generate a raster based on the
values of the vector layer and to be limited by the boundaries provided by
the mask, which in my opinion could be a vector Polygon as well.
I would say this is a pretty major feature.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1775#comment:5&gt;
      Cpu: Unspecified |
Comment(by neteler):
More generally:
Also in my opinion it would be good to have a mask= parameter available
for the other
interpolation modules.
See also the comment about v.surf.icw here:
http://gis.stackexchange.com/questions/85387/how-to-interpolate-a-point-
vector-layer-inside-a-boundary-polygon-layer-qgis-g
Ticket URL: <https://trac.osgeo.org/grass/ticket/1775#comment:6&gt;
      Cpu: Unspecified |
Comment(by cmbarton):
Replying to [comment:6 neteler]:
> More generally:
for the other
I definitely agree!
Ticket URL: <https://trac.osgeo.org/grass/ticket/1775#comment:7&gt;
      Cpu: Unspecified |
Comment(by bhlevca):
Replying to [comment:7 cmbarton]:
available for the other
> I definitely agree!
You would be surprised to know that in ArcGis only two interpolation modes
(geoprocessing IDW and Kernel) can use a mask layer as a barrier. If GRASS
achieve what Markus suggested it will have the upper hand in this domain.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1775#comment:8&gt;
      Cpu: Unspecified |
See also trac #1718 for "ERROR: Input window changed while maps are open
for read".
See also r47601 for related fixed in i.topo.corr: Essentially replace
G_get_set_window(&window); --> Rast_get_window(&window);
From ML: Rast_set_window() should be called before the map is opened.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1775#comment:9&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Fixed in trunk r59737 and relbr70 r59738.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1775#comment:10&gt;
      Type: defect | Status: closed
Component: Vector | Version: svn-releasebranch70
Resolution: fixed | Keywords: v.surf.rst
  Platform: Unspecified | Cpu: Unspecified
Changes (by neteler):
  * status: new => closed
  * version: svn-trunk => svn-releasebranch70
  * resolution: => fixed
Comment:
Checked using the example of the manual page as well as this command:
v.surf.rst elevrand zcol=value elev=elev_fields_masked mask=fields
The mask map is now respected. Closing as fixed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1775#comment:11&gt;
This will automatically fix this same problem in r.fill.nulls too, right?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1775#comment:12&gt;
Replying to [comment:12 cmbarton]:
right?
Seems yes, the manual page example of r.fillnulls runs fine now.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1775#comment:13&gt;
Additional fixes done r62131. It allows to use NULLs (not only zeros) in
the mask and it fixes using standard MASK.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1775#comment:14&gt;
