[GRASS-dev] [GRASS GIS] #1782: wingrass7: installing addons by wxgui-extensions manager fails
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Component: wxGUI | Version: svn-trunk
Keywords: wingrass, python | Platform: MSWindows 7
      Cpu: x86-64 |
hi,
following tested:
Settings => Add extensions => Install extensions of [g.extension]
- message box opens: g.extensions.py - choose the program to open this
file
- closing this message box, the wxgui "Fectch & install from GRASS-addons"
opens
- press button "Fetch", again message box "g.extensions.py - choose the
program to open this file" opens
- closing message box, an error message opens "Error: access denied"
- press button "Command dialog", again message box "g.extensions.py
- choose the program to open this file" opens
- closing message box, the g.exteniosn-wxgui opens and pre-combiled addons
binaries are installed
Helmut
System Info
GRASS version: 7.0.svn
GRASS SVN Revision: 53670M
GIS Library Revision: 52468 (2012-07-27)
GDAL/OGR: GDAL 1.9.2, released 2012/10/08
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.2
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1782&gt;
      Cpu: x86-64 |
Description changed by neteler:
Old description:
hi,
following tested:
file
addons" opens
addons binaries are installed
Helmut
System Info
Python: 2.7.2
wxPython: 2.8.12.1
New description:
hi,
following tested:
  * message box opens: g.extensions.py - choose the program to open this
file
  * closing this message box, the wxgui "Fetch & install from GRASS-addons"
opens
  * press button "Fetch", again message box "g.extensions.py - choose the
  * closing message box, an error message opens "Error: access denied"
  * press button "Command dialog", again message box "g.extensions.py
  * choose the program to open this file" opens
  * closing message box, the g.extension-wxgui opens and pre-combiled
Helmut
System Info
Python: 2.7.2
wxPython: 2.8.12.1
Ticket URL: <http://trac.osgeo.org/grass/ticket/1782#comment:1&gt;
      Cpu: x86-64 |
Comment(by neteler):
Is this still failing?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1782#comment:2&gt;
