[GRASS-dev] [GRASS GIS] #1787: Profile Analysis Tool Problems
Reporter: stu | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Default | Version: 6.4.3 RCs
Keywords: | Platform: Unspecified
      Cpu: OSX/Intel |
The following bugs appear to exist in the Profile Analysis Tool when run
in GRASS 6.4.3 on OS X 10.6.8 and 10.7.5:
1. Save Profile Data to csv file gives this error:
   File "/Users/cmbarton/grass_dev/release_20121024_grass_6_4
_3RC1/dist.x86_64-apple-
darwin12.2.0/etc/wxpython/wxplot/profile.py", line 343, in
SaveProfileToFile
timings = self.timings
TypeError
string indices must be integers
2. Plot display is incorrectly scaled. The sampled DEM is in EPSG 3401
(Ohio north SPC, US feet)
Profile start and end points are plotted the correct distance apart, but
the horizontal scale of the actual profile is plotted in meters (i.e. the
plot is compressed in the first ~1/3 of the frame).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1787&gt;
      Cpu: OSX/Intel |
Changes (by stu):
* cc: stu (added)
Comment:
This appears to be an OS X problem as it was not replicated using the same
data set on 6.4.1 running on Ubuntu 12.04 through Parallels.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1787#comment:1&gt;
Component: wxGUI | Version: 6.4.3 RCs
Keywords: profile tool | Platform: Unspecified
      Cpu: OSX/Intel |
Changes (by martinl):
  * keywords: => profile tool
  * component: Default => wxGUI
Ticket URL: <http://trac.osgeo.org/grass/ticket/1787#comment:2&gt;
      Cpu: OSX/Intel |
Comment(by stu):
Replying to [comment:2 martinl]:
bad analysis on my part - I found an old 6.4.1 on my OS X side and the
profile tool worked fine. So it must be some time after 6.4.1 that it
broke - at least on OS X 10.6.8
Ticket URL: <http://trac.osgeo.org/grass/ticket/1787#comment:3&gt;
      Cpu: OSX/Intel |
Comment(by cmbarton):
The error message reported in #1 doesn't make sense. Line 343 of
profile.py is:
pfile = path+'_'+str(r['name'])+'.csv'
I also don't understand how a path on my computer is showing up in the
error message since "path" in line 343 is defined by:
path = dlg.GetPath()
This doesn't at all look like GRASS 6.4.3
Ticket URL: <http://trac.osgeo.org/grass/ticket/1787#comment:4&gt;
      Cpu: OSX/Intel |
Comment(by stu):
Replying to [comment:4 cmbarton]:
profile.py is:
Sorry to report that it is indeed 6.4.3
I downloaded and reinstalled the 6.4.3 binary and was able to replicate
these errors.
The same function (Profile tool - save to csv) produces the following in
GRASS 7.0 svn
''Traceback (most recent call last):
   File "/Users/Shared/grass_dev/grass70_dev/dist.x86_64
-apple-darwin12.2.0/etc/gui/wxpython/wxplot/profile.py",
line 340, in SaveProfileToFile
ppt, pit, pet, pfn, pframe, pcur = rcur
TypeError
The plot itself has the same characteristics as reported in the bug report
for 6.4.3
Ticket URL: <http://trac.osgeo.org/grass/ticket/1787#comment:5&gt;
      Cpu: OSX/Intel |
Comment(by martinl):
Replying to [comment:5 stu]:
these errors.
RC1 or latest SVN? Recently I have fixed several bugs in profile tool -
see r53696.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1787#comment:6&gt;
Priority: major | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: profile tool r.profile | Platform: Linux
      Cpu: x86-64 |
Changes (by dadudeman):
  * priority: normal => major
  * platform: Unspecified => Linux
  * version: 6.4.3 RCs => svn-trunk
  * milestone: 6.4.3 => 7.1.0
  * keywords: profile tool => profile tool r.profile
  * cpu: OSX/Intel => x86-64
Comment:
Used r.profile interactively in GRASS 7.1 SVN. Same problems described by
stu. If I use horizontal and vertical units of meters, the plot is
perfect. If I change to horizontal and vertical units of feet, the Y axis
of elevations is displayed correctly, but the X axis is squished to stop
at the unit value in meters rather than feet. Example: I had a 800 meter
transect, but when reprojected to feet and profiled, the graph stops at
800 feet rather than the approximate 2600. The endpoint triangle,
however, is placed around the 2600 distance. It's as if it thinks the
units are meters horizontal.
I get a seemingly related issue when I use the measure tool, as the
distances are reported as units meters, but the values are reported
correctly as feet.
I also tested this with grass 6.4 binary.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1787#comment:7&gt;
      Cpu: x86-64 |
Comment(by annakrat):
Replying to [comment:7 dadudeman]:
correctly as feet.
I actually fixed the measurement tool yesterday (r61132). The problem is I
guess that the units are FootUSs which is not recognized as feet. So now
the original units are displayed as footuss which is still kind of weird
but not wrong at least.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1787#comment:8&gt;
Keywords: profile tool r.profile | Platform: All
      Cpu: x86-64 |
Changes (by annakrat):
  * platform: Linux => All
Comment:
by stu. If I use horizontal and vertical units of meters, the plot is
Yes, it's meters because meters come from r.profile and the GUI profiling
tool just takes the values as they are. I wonder if this should be changed
in r.profile rather than in the GUI?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1787#comment:9&gt;
      Cpu: x86-64 |
Replying to [comment:8 annakrat]:
correctly as feet.
I guess that the units are FootUSs which is not recognized as feet. So
now the original units are displayed as footuss which is still kind of
weird but not wrong at least.
Backported in r61268.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1787#comment:10&gt;
      Cpu: x86-64 |
Replying to [comment:9 annakrat]:
described by stu. If I use horizontal and vertical units of meters, the
plot is perfect. If I change to horizontal and vertical units of feet,
the Y axis of elevations is displayed correctly, but the X axis is
squished to stop at the unit value in meters rather than feet. Example:
I had a 800 meter transect, but when reprojected to feet and profiled, the
graph stops at 800 feet rather than the approximate 2600. The endpoint
triangle, however, is placed around the 2600 distance. It's as if it
thinks the units are meters horizontal.
profiling tool just takes the values as they are. I wonder if this should
be changed in r.profile rather than in the GUI?
I fixed this problem in GUI (r61269). Please test. Still it would be worth
changing the behavior of r.profile (and then revert this commit).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1787#comment:11&gt;
      Cpu: x86-64 |
Yes. The proper place to fix this is in r.profile rather than a patch in
the GUI, no matter how welcome.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1787#comment:12&gt;
      Cpu: x86-64 |
Comment(by mlennert):
Replying to [comment:11 annakrat]:
worth changing the behavior of r.profile (and then revert this commit).
This immediately raises once again the question of whether such temporary
workaround fixes are really a good idea, especially when we know that a
fix is actually needed elsewhere. Now that this actually seems to work,
the needed fix is in risk of oblivion.
I personally would plead for not applying such temporary fixes...
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/1787#comment:13&gt;
      Cpu: x86-64 |
Replying to [comment:13 mlennert]:
temporary workaround fixes are really a good idea, especially when we know
that a fix is actually needed elsewhere. Now that this actually seems to
work, the needed fix is in risk of oblivion.
Well, I tried to fix it in r.profile, but I failed. I couldn't find a
correct way to get the meter-whateverfeet conversion. The problem is that
in the US they apparently use FootUS instead of feet, so the standard
grass mechanism for handling units fails to recognize it as feet. (Survey
foot = 0.3048006096, international foot = 0.3048). g.proj, on the other
hand, gives correct conversion.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1787#comment:14&gt;
      Cpu: x86-64 |
Any recommendation if I should backport r61269 for the upcoming beta3? I
am not going to fix r.profile any time soon (I don't know how).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1787#comment:15&gt;
Keywords: profile tool, r.profile, units, g.proj | Platform: All
      Cpu: x86-64 |
Changes (by wenzeslaus):
  * keywords: profile tool r.profile => profile tool, r.profile, units,
               g.proj
  * version: svn-trunk => 6.4.3
Comment:
The foot/meter issue of profile (second originally reported problem) was
reported also in #1273.
If the first originally reported problem was fixed and the GUI works now
fine, this should be closed and new ticket should be opened against
r.profile and r61269.
I'm closing #1273 as duplicate since most of the discussion is here.
Reopen #1273 if scale in GUI is still not working.
Changing version to reported one.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1787#comment:16&gt;
      Type: defect | Status: closed
  Priority: major | Milestone: 7.0.0
Resolution: fixed | Keywords: profile tool, r.profile, units, g.proj
  Platform: All | Cpu: x86-64
  * status: new => closed
  * resolution: => fixed
  * milestone: 7.1.0 => 7.0.0
Comment:
Backported fix for profiling tool in r61910. I created a new ticket #2417
for r.profile.
Reopen if needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1787#comment:17&gt;
