[GRASS-dev] [GRASS GIS] #1788: r.viewshed binary flag (-b) not working correctly
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Component: Raster | Version: svn-trunk
Keywords: r.viewshed | Platform: Unspecified
      Cpu: Unspecified |
The binary flag for r.viewshed makes viewed areas = 1 but unviewed areas =
null(). Unviewed areas are supposed to be = 0.
For example:
r.viewshed -b input=elevation@PERMANENT output=a_view
coordinate=634681,221947
GRASS 7.0.svn (nc_spm_08):~ > r.info -r a_view
min=1
max=1
Ticket URL: <http://trac.osgeo.org/grass/ticket/1788&gt;
      Cpu: Unspecified |
Comment(by annakrat):
I attached a patch for this. If there are no objections, I will commit it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1788#comment:1&gt;
      Cpu: Unspecified |
Replying to [comment:1 annakrat]:
it.
Done in r62467. The failing tests should be fixed tomorrow, I will
backport it then.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1788#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.viewshed
  Platform: Unspecified | Cpu: Unspecified
Changes (by annakrat):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:2 annakrat]:
it.
backport it then.
Done in 62497. Tests are running fine, so I take it as fixed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1788#comment:3&gt;
      Type: defect | Status: reopened
Resolution: | Keywords: r.viewshed
* status: closed => reopened
* resolution: fixed =>
Comment:
Reopened because it works only when using internal memory. When using
external memory mode, binary output gives 1 and nulls. It doesn't seem to
be so easily fixable as the in-memory case, because I can't find an easy
way to find out which cell should be 0 and which should be null.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1788#comment:4&gt;
