#1795: segmentation fault in v.distance db_describe_table
Reporter: pertusus | Owner: grass-dev@…
Type: defect | Status: new
Component: Vector | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-64 |
For a very simple case v.distance segfaults. It is strange, it may be that
my setup has some issues, but I have no obvious idea.
The backtrace is:
gdb --args v.distance from=test_point to=test_bas column=cat_basin
to_column=cat upload=to_attr
Program received signal SIGSEGV, Segmentation fault.
db_describe_table (driver=0x0, name=0x7fffffffb130, table=0x7fffffffb148)
at c_desc_table.c:33
33 db__set_protocol_fds(driver->send, driver->recv);
(gdb) bt #0 db_describe_table (driver=0x0, name=0x7fffffffb130,
table=0x7fffffffb148) at c_desc_table.c:33 #1 0x00007ffff7b98a8c in db_column_sqltype (driver=<value optimized out>,
tab=0x65fd40 "test_point", col=0x61b080 "cat_basin") at column.c:63 #2 0x00007ffff7b98b29 in db_column_Ctype (driver=<value optimized out>,
tab=<value optimized out>, col=<value optimized out>) at column.c:103 #3 0x0000000000406c04 in main (argc=64, argv=<value optimized out>) at
main.c:487
I attach a tarball that allows to reproduce the segfault. You should edit
prepare.sh to set the correct path to grass, then run
Keywords: v.distance | Platform: Linux
Cpu: x86-64 |
Comment(by mmetz):
Replying to [comment:3 pertusus]:
> Indeed, there is no more segfault anymore, but v.distance do not upload
to the table.
> Should I open another bug?
