GDAL
November 19, 2012, 6:29pm
1
#1802: Change in input for graph function in r.mapcalc
Reporter: pvanbosgeo | Owner: grass-dev@…
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
The input for the graph function in r.mapcalc is a string with XY values,
like:
"newmap = graph(map, x1,y1, x2,y2,... xi,yi)"
Often, X and Y values are available as separate columns or vectors. In
such cases, it would be much easier if X and Y values can be given as
separate vectors, e.g., something like:
"newmap = graph(map, x1,x2,x3,x4,...xi, y1,y2,y3,y4,...,yi)"
Glynn Clements has already created a patch to implement this, see
http://lists.osgeo.org/pipermail/grass-dev/2012-November/060851.html . I
would like to suggest to implement this patch which will add a graph2()
function with the above syntax
Ticket URL: <http://trac.osgeo.org/grass/ticket/1802> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
November 20, 2012, 11:14am
2
Component: Raster | Version: svn-trunk
Keywords: r.mapcalc | Platform: Unspecified
Cpu: Unspecified |
Changes (by martinl):
* keywords: => r.mapcalc
* version: unspecified => svn-trunk
* component: Default => Raster
Ticket URL: <http://trac.osgeo.org/grass/ticket/1802#comment:1> ;
GDAL
March 26, 2014, 2:33pm
3
Cpu: Unspecified |
Comment(by neteler):
Patch applied in r59362: new graph2() function added.
Closing here, reopen if needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1802#comment:2> ;
GDAL
March 26, 2014, 3:23pm
4
Type: enhancement | Status: closed
Resolution: fixed | Keywords: r.mapcalc
Platform: Unspecified | Cpu: Unspecified
* status: new => closed
* resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/1802#comment:3> ;
