#1815: Problem with menu "path to GRASS database" in v.proj en r.proj windows
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Component: Default | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-64 |
Browsing to the folder with the GRASS database in the menu "path to GRASS
database" in v.proj and r.proj windows does not work. It always shows the
home folder whatever folder you select.
Component: Website | Version: svn-trunk
Keywords: r.proj, v.proj | Platform: Linux
Cpu: x86-64 |
Changes (by martinl):
Component: wxGUI | Version: svn-trunk
Cpu: x86-64 |
