#1821: r.water.outlet: accept vector points map instead of plain coordinates for
outlet
Reporter: dericke | Owner: grass-dev@…
Component: Raster | Version: unspecified
Keywords: watershed | Platform: Unspecified
Cpu: Unspecified |
Similar to r.walk, r.water.outlet should accept either an easting and
northing (as it currently does), or a points map (with optional SQL query)
to define the outlet point(s).
The cat field of the points file could be optionally used as the raster
value for each basin created.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1821>
