#1825: r.tileset only returns one tile
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Component: Raster | Version: svn-trunk
Keywords: r.tileset | Platform: Unspecified
Cpu: Unspecified |
Comment(by sbl):
Some variant of the same problem I guess:
On Ubuntu I get no tiles listed:
On my Windows box I get this error-message:
GRASS 7.0.svn> r.tileset sourceproj="+proj=utm +no_defs +zone=33
+a=6378137 +rf=298.257223563 +towgs84=0.000,0.000,0.000 +to_meter=1"
maxcols=25000 maxrows=25000 overlap=10
sh: r.tileset: command not found
On my Ubunut box no tiles are printed at all:
GRASS 7.0.svn (Norge_33N_WGS84):~ > r.tileset sourceproj="+proj=utm
+no_defs +zone=33 +a=6378137 +rf=298.257223563 +towgs84=0.000,0.000,0.000
+to_meter=1" maxcols=25000 maxrows=25000 overlap=10
Computing tiling...
Looks like a declaration of floating type variables I necessary, when the
tile_bbox w,s,e,n coordinates are calculated.
Furthermore, the bboxesIntersect() method does not work properly.
The provided patch should fix these issues.
But there will be still a rounding oddity, because my regions n,s,e,w have
no digits, while the tiles get some:
GRASS 7.0.svn (Norge_33N_WGS84):~ > g.region -up
projection: 1 (UTM)
zone: 33
datum: wgs84
ellipsoid: wgs84
north: 7972675
south: 6415595
west: -97865
east: 1165535
nsres: 10
ewres: 10
rows: 155708
cols: 126340
cells: 19672148720
GRASS 7.0.svn (Norge_33N_WGS84):~ > r.tileset1.py sourceproj="+proj=utm
+to_meter=1" maxcols=25000 maxrows=25000 overlap=10 --v
Projecting destination region into source...
Projecting source bounding box into destination...
Computing length of sides of source bounding box...
Computing tiling...
There will be 6 by 7 tiles each 21057 by 22244 cells
-97864.9638333|6415594.9703|112801.679274|6638134.85547|21067|22254
-97864.9638333|6638034.85552|112801.679274|6860674.74064|21067|22254
-97864.9638333|6860474.74074|112801.679274|7083214.62581|21067|22254
-97864.9638333|7082914.62596|112801.679274|7305754.51097|21067|22254
Ticket URL: <http://trac.osgeo.org/grass/ticket/1825#comment:2>
