[GRASS-dev] [GRASS GIS] #1828: v.kernel's "Standard deviation in map units" field is not clear
Reporter: arencambre | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: 6.4.2
Keywords: | Platform: MSWindows 7
      Cpu: x86-64 |
Discussing with Markus Metz, it's apparent that v.kernel's '''Standard
deviation in map units''' field is unclear and has different meanings
depending on the kernel function used. E.g., the actual kernel radius is
currently a function of the SD and the selected kernel function.
USers should be just asked for the radius in map units. The SD would be
adjusted as necessary depending on the function.
It may be OK to retain an SD field for advanced cases, but it should not
be on the '''Required''' tab of the v.kernel UI.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1828&gt;
Keywords: v.kernel | Platform: MSWindows 7
      Cpu: x86-64 |
Changes (by martinl):
  * keywords: => v.kernel
  * milestone: 6.4.3 => 7.0.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/1828#comment:1&gt;
      Cpu: x86-64 |
Comment(by neteler):
Was changed in r54271
Ticket URL: <http://trac.osgeo.org/grass/ticket/1828#comment:2&gt;
Keywords: v.kernel | Platform: All
      Cpu: x86-64 |
Changes (by neteler):
  * platform: MSWindows 7 => All
Comment:
Is this solved?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1828#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.kernel
  Platform: All | Cpu: x86-64
Changes (by mlennert):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:3 neteler]:
> Is this solved?
AFAIU, yes, so closing.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/1828#comment:4&gt;
