#1829: Allow user to override MAPSET ownership check
Reporter: marisn | Owner: grass-dev@…
Priority: minor | Milestone: 7.0.0
Component: Startup | Version: svn-trunk
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Currently it is not possible to work with MAPSETs that are not owned by
current user. There is a good historic reason for such design decision,
still it would be nice to provide users an option to override this
ownership check. It would not harm anyone on a single user system and, as
usual, users enabling this override must blame them self if any harm is
done.
Without looking at code, it could be implemented as a startup
switch/checkbox in GUI + a GISENV variable to enforce it subsequently.
Design must be adopted according to existing code.
This works. I've just tried this in Python. It was very helpful, by the
way.
However, I don't know how to support this in GUI.
1) It is env variable not gisenv variable, so it is per-process. GUI
cannot set it for command line. Two solutions:
* set the variable on grass start-up (the safe way, but still, I don't
know how to transfer the wxGUI settings to start-up script)
* change this to gisenv variable (consequences?)
2) Where to put the check in the GUI?
3) Do we even need to support this in GUI (it is a very special thing)?
Can we close this ticket as fixed now?
Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:2 wenzeslaus]:
I could comment it in the sense how it's done for `GRASS_ADDON_PATH`
variable (menu: File->Launch script). If the script is not in the path,
the GUI updates loaded environmental variable
(`os.environ['GRASS_ADDON_PATH']=`) and updates `.grass7/basrc` (or
`GRASS7\env.bat` on MS Windows). This file is loaded by the initialization
script. Drawback: if you quit GUI and launch it again, the variable is
lost - you need to restart GRASS (launch initialization script which
loads `bashrc` or `env.bat` file).
Cpu: Unspecified |
Comment(by hamish):
(a bit off-topic, but for anyone who didn't know these non-obvious points
already it's worth repeating)
n.b. 1) in GRASS 6 GRASS_ADDON_PATH needs to be set in ~/.bashrc not
~/.grass.bashrc since .grass.bashrc is run last, after the PATH and
everything else is already set up. GRASS_HTML_BROWSER is another in the
same situation, see `grass64 --help` for the full list.
n.b. 2) the script needs to be in the path for g.parser to function
correctly. Compiled C modules don't need to be in the path though.
Cpu: Unspecified |
Replying to [comment:4 hamish]:
Cpu: Unspecified |
Comment(by glynn):
I'm not sure you should support it in the GUI. It should be set on single-
user systems, and unset on multi-user systems. On a given system, there's
no reason for the user to change it.
Replying to [comment:6 glynn]:
single-user systems, and unset on multi-user systems. On a given system,
there's no reason for the user to change it.
OK, because there is no need to set it from GUI and the programmer's way
is available, I'm closing the ticked as fixed.
