#1841: segmentation fault in v.patch
Reporter: pertusus | Owner: grass-dev@…
Type: defect | Status: new
Component: Vector | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-64 |
A very simple v.patch segfaults. I tried to poke around in the code, and I
found some leads, but I cannot really dig further. It is somewhat strange
that nobody else stumbled on it.
I attach a tarball to reproduce. Simply unpack, edit
bug_v_patch.sh if you want to change the paths to grass, then run
bug_v_patch.sh:
Writing attributes...
./bug_v_patch.sh: line 35: 32630 Segmentation fault v.patch -e -a
input=test_bug_v_patch_one output=test_bug_v_patch_two --o
I produced a backtrace from within the grass shell
> gdb --args v.patch -e -a input=test_bug_v_patch_one
(gdb) run
Program received signal SIGSEGV, Segmentation fault.
__strcpy_ssse3 () at ../sysdeps/x86_64/multiarch/strcpy.S:177
177 movdqa %xmm1, (%rdi) /* store first 16 bytes into
rdi */
(gdb) bt
#0 __strcpy_ssse3 () at ../sysdeps/x86_64/multiarch/strcpy.S:177
#1 0x00007ffff79882de in set_string (x=0x7fffffffdd50, s=<value optimized
out>, copy=<value optimized out>)
at string.c:101
#2 0x0000000000402d08 in main (argc=<value optimized out>, argv=<value
optimized out>) at main.c:285
(gdb)
trying to look at what happens
(gdb) break main.c:285
Breakpoint 1 at 0x402cf7: file main.c, line 285.
(gdb) run
Breakpoint 1, main (argc=<value optimized out>, argv=<value optimized
out>) at main.c:285
285 db_set_string(&table_name_out, fi_out->table);
(gdb) print table_name_out
$1 = {string = 0x0, nalloc = 21}
(gdb)
The string pointer maybe should not be NULL.
Looking at what point it becomes null, by poking in gdb, I found that in
fact the string is filled correctly at l 139, and if I set a breakpoint I
can see its value. I set a new breakpoint at line 154, I can see that the
string is set to null at that point (I also have a breakpoint l 156):
(gdb) break main.c:154
Breakpoint 4 at 0x4029f9: file main.c, line 154.
(gdb) run
Breakpoint 4, main (argc=<value optimized out>, argv=<value optimized
out>) at main.c:154
154 Vect_open_old_head(&InMap, in_name, "");
$3 = {string = 0x800ed0 "test_bug_v_patch_two", nalloc = 21}
(gdb) n
Breakpoint 2, main (argc=<value optimized out>, argv=<value optimized
out>) at main.c:156
156 fi_in = Vect_get_field(&InMap, 1);
$4 = {string = 0x0, nalloc = 21}
Ticket URL: <http://trac.osgeo.org/grass/ticket/1841>
