GDAL
January 3, 2013, 3:45am
1
#1843: grass-6.4.2 doesn't compile with tk-8.6.0
Reporter: syntaxerrormmm | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Default | Version: 6.4.2
Keywords: | Platform: Linux
Cpu: x86-64 |
OS: ArchLinux (rolling release)
Behaviour: compiling GRASS from source (6.4.2) fails when building NVIZ
with the attached error.
It seems that the required function (TkCopyAndGlobalEval) has been removed
from the TK toolkit (8.6.0).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1843> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
January 3, 2013, 9:49am
2
Priority: critical | Milestone: 6.4.3
Component: Compiling | Version: 6.4.2
Cpu: x86-64 |
Changes (by martinl):
* priority: normal => critical
* component: Default => Compiling
Ticket URL: <http://trac.osgeo.org/grass/ticket/1843#comment:1> ;
GDAL
January 5, 2013, 9:50am
3
Cpu: Unspecified |
Changes (by syntaxerrormmm):
* cpu: x86-64 => Unspecified
Comment:
Verified also on i686. Cannot confirm for other platforms, sorry.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1843#comment:2> ;
GDAL
January 5, 2013, 12:32pm
4
Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:2 syntaxerrormmm]:
related to
source:grass/branches/releasebranch_6_4/visualization/nviz/src/draw.c#L35
any tcl/tk guru here?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1843#comment:3> ;
GDAL
5
Priority: blocker | Milestone: 6.4.3
Cpu: Unspecified |
* priority: critical => blocker
Ticket URL: <http://trac.osgeo.org/grass/ticket/1843#comment:4> ;
GDAL
January 5, 2013, 1:56pm
6
Cpu: Unspecified |
Comment(by syntaxerrormmm):
I can confirm grass_7 from SVN does compile fine on tk-8.6.0 (x86_64). Is
there any ways to backport changes made to NVIZ to 6.4 branch?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1843#comment:5> ;
GDAL
January 5, 2013, 3:47pm
7
Cpu: Unspecified |
Replying to [comment:5 syntaxerrormmm]:
Is there any ways to backport changes made to NVIZ to 6.4 branch?
there is *no* TCL/TK code in GRASS 7, it's reason why compiles fine
against TCL/TK 8.6.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1843#comment:6> ;
GDAL
January 5, 2013, 4:30pm
8
Cpu: Unspecified |
Replying to [comment:6 martinl]:
against TCL/TK 8.6.
Ok, sorry, I didn't follow GRASS 7 development.
I'm trying to make a package of GRASS for ArchLinux, so probably the best
way (by my side) is to require a version of TK < 8.6.0, hoping that you
can fix it in the meantime. I should also notice the maintainer of the
7-svn package, since TCL/TK shouldn't be a requirement anymore.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1843#comment:7> ;
GDAL
January 5, 2013, 7:16pm
9
Cpu: Unspecified |
Comment(by mmetz):
Replying to [ticket:1843 syntaxerrormmm]:
> OS: !ArchLinux (rolling release)
> It seems that the required function (!TkCopyAndGlobalEval) has been
removed from the TK toolkit (8.6.0).
Within !Tcl/Tk,
TkCopyAndGlobalEval(interp, command);
has been replaced with
Tcl_EvalEx(interp, command, -1, TCL_EVAL_GLOBAL);
see
http://rkeene.org/projects/tcl/tk.fossil/ci/bd1165a06d?sbs=0
Maybe the equivalent
Tcl_EvalEx(cancel_interp, cancel_script, -1, TCL_EVAL_GLOBAL);
works for GRASS 6? `Tcl_EvalEx` exists in previous versions of !Tcl/Tk
(8.5 + 8.4).
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1843#comment:8> ;
GDAL
January 12, 2013, 8:45am
10
Cpu: Unspecified |
Comment(by marisn):
I tested Markus M proposed Tcl_EvalEx change and didn't observe any side
effects with tcl 8.6 I would say +1 for commiting.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1843#comment:9> ;
GDAL
January 21, 2013, 10:55pm
11
Cpu: Unspecified |
I apologize for the long delay.
I just tested compiling GRASS 6.4.2 on Archlinux with Tcl/Tk 8.6 and it is
compiling fine, on both architectures x86_64 and i686, using the attached
patch (as proposed by Markus M). I cannot check the real functionality of
the fix since I don't have any idea on how the change would impact on
GRASS functionalities.
But +1 for committing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1843#comment:10> ;
GDAL
January 21, 2013, 11:30pm
12
Cpu: Unspecified |
Comment(by yarma):
hi,
applied the fix on draw.c and it's compiling again without error ...
didn't test if there is side effect, but it seems to be working !
Sylvain
Ticket URL: <http://trac.osgeo.org/grass/ticket/1843#comment:11> ;
GDAL
January 27, 2013, 9:41pm
13
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:11 yarma]:
> hi,
I have applied the fix for GRASS 6 in r54796-7. Please test!
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1843#comment:12> ;
GDAL
January 28, 2013, 9:58pm
14
Cpu: Unspecified |
Comment(by msieczka):
Replying to [comment:12 mmetz]:
I have just built releasebranch_6_4 and develbranch_6 on Arch against
tcl/tk 8.6.0, and given tcl/tk startup, gis.m and NVIZ a quick spearfish60
tour in both builds. No problems noticed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1843#comment:13> ;
GDAL
February 3, 2013, 1:46pm
15
Type: defect | Status: closed
Resolution: fixed | Keywords:
Platform: Linux | Cpu: Unspecified
* status: new => closed
* resolution: => fixed
Comment:
Seems to be solved, so closing this ticket. Feel free to re-open if
needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1843#comment:14> ;
