[GRASS-dev] [GRASS GIS] #1845: v.buffer: strange result for lines
Reporter: martinl | Owner: grass-dev@…
     Type: defect | Status: new
Component: Vector | Version: svn-trunk
Keywords: v.buffer, lines | Platform: Linux
      Cpu: x86-64 |
Sample data attached: attachment:silnice.txt
Buffer 1000m - OK (attachment:vector_1000.png)
v.buffer input=silnice output=silnice1000 distance=1000
Buffer 100m (using GEOS) - surprisingly wrong
(attachment:vector_100_geos.png)
v.buffer input=silnice output=silnice100 distance=100
Buffer 100m (using GRASS) - wrong - not surprisingly
(attachment:vector_100_grass.png)
export GRASS_VECTOR_BUFFER=1
Ticket URL: <http://trac.osgeo.org/grass/ticket/1845&gt;
Priority: critical | Milestone: 7.0.0
      Cpu: x86-64 |
Changes (by martinl):
  * priority: normal => critical
Old description:
New description:
Buffer 1000m - OK (attachment:v_buffer_1000.png)
(attachment:v_buffer_100_geos.png)
(attachment:v_buffer_100_grass.png)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1845#comment:1&gt;
      Cpu: x86-64 |
Comment(by mmetz):
Replying to [ticket:1845 martinl]:
Works for me. Do you have any changes in your local copy?
Looks better for me, but still with errors.
I'm using GEOS-3.3.6.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1845#comment:2&gt;
      Cpu: x86-64 |
Comment(by martinl):
Replying to [comment:2 mmetz]:
hm, it fails only with original binary map (attachment:silnice.pack), not
with imported ascii map.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1845#comment:3&gt;
      Cpu: x86-64 |
Comment(by mmetz):
Replying to [comment:3 martinl]:
not with imported ascii map.
The original binary map is 3D, the imported ascii map is 2D. I guess one
of the cleaning tools does not work with 3D output, even though v.buffer
creates 2D output. Strange.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1845#comment:4&gt;
Keywords: v.buffer, lines, 3D input | Platform: Linux
      Cpu: x86-64 |
  * keywords: v.buffer, lines => v.buffer, lines, 3D input
Comment:
Replying to [comment:4 mmetz]:
I overlooked it, good point.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1845#comment:5&gt;
      Cpu: x86-64 |
Comment(by mmetz):
Should be fixed in r54529.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1845#comment:6&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.buffer, lines, 3D input
  Platform: Linux | Cpu: x86-64
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:6 mmetz]:
Confirmed, thanks for super-quick fix.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1845#comment:7&gt;
