[GRASS-dev] [GRASS GIS] #1846: Query vector map tool does not work
Reporter: pvanbosgeo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: | Platform: Linux
      Cpu: x86-64 |
The query vector/raster map tool on a vector layer does not work. When
clicking on a layer, the rendering bar in the map display window get's
stuck somewhere on 50-75%. Moreover, the mouse cursor keeps on spinning
when hovering over any GRASS window, also after I close the map display
window (I thought it was related to the rendering of the map).
I am working on GRASS 7 r54557 (but it started in a previous revision), on
Ubuntu 12.10, with Python 2.7.3 and wxPython 2.8.12.1. I marked this as a
major problem as this affects a key functionality i.m.h.o.
The command line output when trying to query a vector layer is:
   File "/usr/local/grass7/grass-7.0.svn/etc/gui/wxpython/map
disp/mapwindow.py", line 969, in MouseActions
self.OnLeftUp(event)
disp/mapwindow.py", line 1164, in OnLeftUp
self.frame.Query(self.mouse['begin'][0],self.mouse['begin'][
1], layers)
disp/frame.py", line 685, in Query
self.QueryVector(east, north, qdist, posWindow, layers[0])
disp/frame.py", line 837, in QueryVector
self.MapWindow.UpdateMap(render = False, renderVector =
False)
disp/mapwindow.py", line 612, in UpdateMap
self.mapfile = self.Map.Render(force = False, mapWindow =
self.frame)
   File "/usr/local/grass7/grass-7.0.svn/etc/gui/wxpython/cor
e/render.py", line 963, in Render
maps, masks, opacities =
self.GetMapsMasksAndOpacities(force, mapWindow, windres)
e/render.py", line 933, in GetMapsMasksAndOpacities
return self._renderLayers(force, guiFrame)
e/render.py", line 901, in _renderLayers
if not layer.Render():
e/render.py", line 148, in Render
ret, msg = self._runCommand(c)
e/render.py", line 192, in _runCommand
**self.cmd[1])
IndexError
list index out of range
Ticket URL: <http://trac.osgeo.org/grass/ticket/1846&gt;
      Cpu: x86-64 |
Comment(by pvanbosgeo):
This bug is related to the rendering of the map. If I disable rendering in
the Map display window, the query tool works. Also note that the query
tool works without problems in 6.4.3 (obviously the vector layer has to be
rebuild first).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1846#comment:1&gt;
      Type: defect | Status: closed
  Priority: trivial | Milestone: 7.0.0
Resolution: invalid | Keywords:
  Platform: Linux | Cpu: x86-64
Changes (by pvanbosgeo):
  * priority: major => trivial
  * status: new => closed
  * resolution: => invalid
Comment:
OK, not sure what has happened, but reinstalled (the same version of)
grass 7.0, and it works correctly again. Marking this as invalid.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1846#comment:2&gt;
Component: wxGUI | Version: svn-trunk
Changes (by martinl):
  * component: Default => wxGUI
Ticket URL: <http://trac.osgeo.org/grass/ticket/1846#comment:3&gt;
      Type: defect | Status: reopened
Resolution: | Keywords:
Changes (by mmetz):
  * priority: trivial => major
  * status: closed => reopened
  * resolution: invalid =>
Comment:
Replying to [comment:2 pvanbosgeo]:
Reopening because I get the exact same error with r54582. No changes in my
local copy, a brand new .grass7/wx file.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1846#comment:4&gt;
Comment(by mmetz):
Replying to [comment:4 mmetz]:
Hopefully fixed in r54585, but the change needs review.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1846#comment:5&gt;
Resolution: fixed | Keywords: query
Changes (by annakrat):
  * keywords: => query
  * status: reopened => closed
  * resolution: => fixed
Comment:
Replying to [comment:5 mmetz]:
Thanks for the fix, it seems to be only a copy & paste error. I think we
can close this.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1846#comment:6&gt;
