[GRASS-dev] [GRASS GIS] #1849: Cannot create a new GRASS Location using a custom proj4 string
Reporter: voncasec | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Projections/Datums | Version: unspecified
Keywords: proj,proj.4,proj4,location wizard,wxgui | Platform: Linux
      Cpu: x86-64 |
I have tried this using both grass6.4.3svn release branch (revision 54578)
and grass7.0svn trunk (revision 54587).
Using the wxGUI:
Location Wizard -> [input location name] -> Specify projection and datum
terms using custom PROJ.4 parameters -> [input proj.4 string (eg.
+proj=utm +zone=10 +datum=nad83)] -> NEXT
Error: No output format specified, define one of flags -p,-g,-j or -w
Ticket URL: <http://trac.osgeo.org/grass/ticket/1849&gt;
      Cpu: x86-64 |
Comment(by annakrat):
This patch seems to solve this problem, however I don't really understand
what's going on here. There are also other places when g.proj is called
without specifying flags.
--- location_wizard/wizard.py (revision 54601)
+++ location_wizard/wizard.py (working copy)
@@ -1535,7 +1535,8 @@
              ret, out, err = RunCommand('g.proj',
                                         read = True, getErrorMsg = True,
                                         proj4 = self.customstring,
- datum_trans = '-1')
+ datum_trans = '-1',
+ flags = 'jf')
Ticket URL: <http://trac.osgeo.org/grass/ticket/1849#comment:1&gt;
Priority: critical | Milestone: 6.4.3
Keywords: proj4, location wizard, wxgui | Platform: Linux
      Cpu: x86-64 |
Changes (by hamish):
* cc: pkelly (added)
  * keywords: proj,proj.4,proj4,location wizard,wxgui => proj4, location
               wizard, wxgui
  * priority: normal => critical
Comment:
Hi, testing with the latest relbr64 and devbr6,
in the wxPy loc'n wizard, defining by proj4 terms, using the string:
it asks me to select from transform options 0-6, then when I press Ok to
that, I get a slightly different error printed in the terminal:
   File "/home/hbowman/dev/grass/svn/relbr_6_4/dist.x86_64-unknown-linux-
gnu/
   etc/wxpython/location_wizard/wizard.py", line 1517, in OnPageChanging
     if len(dtrans) == 0:
TypeError: object of type 'int' has no len()
the error that it's checking for is 'Datum transform is required.', -- but
I don't think it's true, grass is happy enough to let you leave the datum
transform undefined in the PROJ_INFO file. (then it gives you a message
about it, "default transform will be used")
If I change the +datum= to wgs84 I get the same "`Error: No output format
specified, define one of flags -p,-g,-j or -w`" error box pops up. (that
message is from g.proj)
from the grass6 command line, this shows the 0-6 transform list:
g.proj proj4='+proj=utm +zone=10 +datum=nad83' datumtrans=-1
but this shows the 'please use a flag' error message:
g.proj proj4='+proj=utm +zone=10 +datum=wgs84' datumtrans=-1
Adding the g.proj '-t' flag to "Force override of datum transformation
information in input co-ordinate system" makes it print the transform opts
correctly (then exit) for both. I assume the wgs84 continues on as it only
has the 1 case to choose from, so it gets back to main() and then wonders
what to do next since no flags were given.
So a quick fix is to add -t, but why is that needed?
The problem seems to have come in with r53453; adding '-jf' flags is not
the correct thing, that just makes it fail differently.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:2&gt;
      Cpu: x86-64 |
Comment(by hamish):
some debug:
# ok datum name, mult options:
G:g.proj > g.proj proj4='+proj=utm +zone=10 +datum=nad83' datumtrans=-1
..force=0
D0/0: set_datumtrans(): GPJ__get_datum_params() status=1
1
Used in whole nad83 region
towgs84=0.000,0.000,0.000
Default 3-Parameter Transformation (May not be optimum for older datums;
use this only if no more appropriate options are available.)
2
Used in Florida
(ok)
# bogus datum name:
G:g.proj > g.proj proj4='+proj=utm +zone=10 +datum=nad839999'
datumtrans=-1
WARNING: Datum <unknown> not recognised by GRASS and no parameters found
..force=0
D0/0: set_datumtrans(): GPJ__get_datum_params() status=-1
D0/0: set_datumtrans(): Datum name either invalid or not supplied.
ERROR: No output format specified, define one of flags -p, -g, -j, or -w
(doesn't quit when it should)
# ok datum name, single option:
G:g.proj > g.proj proj4='+proj=utm +zone=10 +datum=wgs84' datumtrans=-1
..force=0
# same as above w/ -t
G:g.proj > g.proj proj4='+proj=utm +zone=10 +datum=wgs84' datumtrans=-1 -t
..force=1
1
Used in whole wgs84 region
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:3&gt;
      Cpu: x86-64 |
Comment(by hamish):
suggestion: for 6.4.3 throw the '-t' flag in there as a quick hack-around
to get it working for release, then continue to work on the real problem
in dev branches.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:4&gt;
      Cpu: x86-64 |
Comment(by hamish):
Added the -t flag to g.proj in devbr6 for testing, now for the utm 10
example above I still get the python error "`object of type 'int' has no
len()`" from comment:2, but at least the proj4 terms are populated and the
location creates itself ok. I notice that after selecting the default
3-term datum transform that +towgs84=0,0,0,0,0,0,0. No problem since it's
the same as 0,0,0, but perhaps a sign of trouble elsewhere. -- it is,
trying again with the Florida transform grid ends up with the same result,
+towgs84=0,0,0,0,0,0,0 and no grid file selected in the PROJ_INFO file.
different than in comment:2 (which was run on linux), on wingrass 6.5svn I
get the "`define one of flags -p,-g,-j or -w`" error box for nad83 too.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:5&gt;
      Cpu: x86-64 |
Comment(by hamish):
besides the one on line 1500, maybe also needed in wizard.py line 901,
1346?
tried manually adding to latest wingrass 6.4svn build, selected the grid
file by epsg code 27200, but it jumped back to the 7-term default proj4
terms anyway. argh.
specifying from the search list worked (yay), specifying by proj4 terms
fails with:
as in comment:2.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:6&gt;
      Cpu: x86-64 |
Comment(by hamish):
Replying to [comment:6 hamish]:
1346?
committed to relbr6 in r56143.
> specifying by proj4 terms fails with:
> as in comment:2.
no idea about the above Traceback error, but we're getting closer to
having something working for 6.4.3.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:7&gt;
      Cpu: x86-64 |
Comment(by hamish):
current situation of loc wiz + datum transform options in devbr6 nightly
wingrass build: (which uses proj4 4.8.0)
test 1: datum transform selection
  proj: nzmg, datum: nzgd49, (epsg: 27200)
  datum transform: "2" NTv2 grid file
  - setup by terms: works!
  - setup by epsg code: grid file selected but +towgs84= 7-term in Summary
page & loc'n.
  - setup by proj terms: "+proj=nzmg +datum=nzgd49"; grid file selected but
no sign of it in the Summary page and loc'n created with the +towgs84
7-term transform.
test 2: no datum
  - setup by terms: proj -> ll, ellipsoid only -> sphere -> error. (see
trac #1967)
these two things are the last majors blocking release AFAICT.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:8&gt;
      Cpu: x86-64 |
Comment(by hamish):
traceback when specifying by proj4 terms hopefully fixed in devbr6 by
r56160.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:9&gt;
      Cpu: x86-64 |
Comment(by hamish):
(r56160 fixed by r56161, the "test 2: no datum" case is hopefully now
fixed too in devbr6 and trunk)
datum transform selection by epsg code and proj4 terms still broken.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:10&gt;
      Cpu: x86-64 |
Comment(by hamish):
setup by custom proj terms hopefully fixed & working ok in devbr6 as of
r56176 (please test with your local!), similar fixes for epsg remain todo.
an existing bug in the custom proj terms (maybe elsewhere too) is if you
select datum transform opt `0` from the list (i.e. don't specify transform
opts) it picks the grass default one anyway.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:11&gt;
      Cpu: x86-64 |
Comment(by hamish):
Replying to [comment:11 hamish]:
> as of r56176 (please test with your local!), similar fixes for
> epsg remain todo.
epsg, custom proj terms still not right in wingrass+proj 4.8.0, but
looking ok on linux+proj 4.7.0.
It seems that the g.proj -t flag is needed with the 'g.proj -jw' calls to
get the datum transform on the summary page on wingrass+4.8.0, and the -t
flag is also needed in grass.create_location() (in core.py, at least for
epsg-mode) for the g.proj call there.
On wingrass 6.5 I tried 'g.proj -c epsg=27200 datumtrans=2
loc=test_without_t' right on the command line, and without using the -t
flag meant that the datum transform was not added to the resulting
PROJ_INFO file, instead the default proj4-heuristics option was used. With
the -t flag it respected the datumtrans= option.
> too) is if you select datum transform opt `0` from the
> list (i.e. don't specify transform opts) it picks the
this is a bug in g.proj ignoring `datumtrans=0`, or rather falling back to
the grass datum table default (this time, proj4 heuristics choose
differently). As I'm not entirely sure if that should be classed as a bug
or intended feature, I'll file it as another ticket. (seems ok in wingrass
6.5 + proj 4.8.0 but not linux 6.5 + proj 4.7.0)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:12&gt;
      Cpu: x86-64 |
Comment(by hamish):
'g.proj -t' work-around in the wxGUI location wizard now applied in all
branches, which seems to make things better when used with proj 4.8.0.
please everyone test all ways of creating all types of locations, both
with proj 4.7.0 and 4.8.0. Don't trust the summary screen, you need to
confirm the result was as expected with 'g.proj -p' from within the new
session.
still haven't done anything about datumtrans=0, my feeling is that it
should remove all datum transform terms to match its description "Do not
apply any datum transforms", so leave it undefined even if proj 4.8.0 has
decided to choose some default terms itself (i.e. strip away the trying-
to-be-helpfulness).
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:13&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: proj4, location wizard, wxgui
  Platform: Linux | Cpu: x86-64
  * status: new => closed
  * resolution: => fixed
Comment:
Helmut wrote:
> some teste here
> http://lists.osgeo.org/pipermail/grass-user/2013-May/068240.html
> http://lists.osgeo.org/pipermail/grass-user/2013-May/068241.html
> http://lists.osgeo.org/pipermail/grass-user/2013-May/068242.html
> EPSG 3416 ETRS89 / Austria Lambert
can you comment on if the results are as you expect?
the PROJ_INFO file (g.proj -p) is the main result to be concerned with.
Moritz added:
  http://lists.osgeo.org/pipermail/grass-user/2013-May/068239.html
Helmut noticed the same:
> it seems "0 Do not apply any datum transformation" isn't applied?
the PROJ.4 function called by 'g.proj -c' sees there is missing
datum transform opts and decides that it should add one. Which one
it decides to add depends on your version of PROJ.4.
filed as a new bug for 6.4.4 (#1995).
The old text based g.setproj location creation tool doesn't have
this problem since it creates the PROJ_INFO from terms directly.
The wxGUI location wizard during location creation goes something
like grass terms -> +proj terms (summary page) -> WKT -> grass terms.
... much more opportunity for something to happen, but fortunately
the coefficients are pretty well defined. Also it is different if
you define by terms (parsed via g.proj), or set +proj terms directly
(not parsed until the last step, so no defaults added). e.g. if you
define the location by +proj4 terms, and enter "+proj=nzmg
+datum=nzgd49" and select "0: do not apply transform" the summary
page (parsed by g.proj) shows added default transform terms, but
the actual PROJ_INFO in the location (correctly) doesn't have them.
without abandoning the 'g.proj -c' method, I'm not sure of the
best way to solve the problem of avoiding PROJ.4 being helpful
when you want it to be dumb. maybe the best thing to do is to tell
people to look at 'g.proj -p' just to verify it's what you wanted
in a final pop up after the location is created (so we can just
display the PROJ_INFO file as-is), but before it asks about setting
default bounds and creating a new mapset.
(actually it may be OGR channeling PROJ 4.8.0 via GPJ_wkt_to_grass()
and GPJ_osr_to_grass(), and the 4.8.0 thing mostly when starting
with EPSG codes w/o specified transform terms)
> Select WKT or PRJ file
> no asking which transformation should be used.
ok, filed that as a new bug for 6.4.4 (#1994).
> "Used in whole hermannskogel region: towwgs84=653.000,-212.000,449.000"
> is preselected, but not the best e.g. if location used for Austria.
that gets back to the whole mess of trying to decide which is the
best to choose. proj 4.8.0 likes 7-terms (may be more "correct"
in smaller areas) over 3-terms (may be less accuracy at focus but
covers a much wider area). And sometimes the 7-term for a place is
great and the 3-term was poorly derived. It's hard to say.
Generally if using the old-ways GRASS's internal will suggest
the 3-term as the default. See text comments at the start of
$GISBASE/etc/datum.table.
There is no real right or wrong answer, the user will have to do
their homework and make an informed decision for themselves.
(it's all a bit complicated, the above is my best guess and probably not
100% accurate)
The original `+proj=utm +zone=10 +datum=nad83` problem in this ticket is
now fixed in all versions, and besides for the two new tickets most things
seem to be working as expected, so closing the ticket.
Perhaps it would still be good to pop up a window as soon as the location
is created displaying what is in the final PROJ_INFO file, just to be
sure. it wouln't have to say that we somewhat doubt our code, just be
informative saying this is what it ended up with, "ok, continue".
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:14&gt;
