[GRASS-dev] [GRASS GIS] #1855: error using GRASS v.net
Reporter: dof1985 | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Vector | Version: 6.4.2
Keywords: network | Platform: Unspecified
      Cpu: x86-64 |
I am trying to create a network from a polyline map with about 11000
categories and a points map with about 24 categories.
I was using v.net with a threshold of 4500 meters (provided by v.distance)
and receive the following error:
Assertion failed:!p->taken[i], file split_q.e, line 69
My code was:
v.net input=network points=cdw1c output=network_v1 operation=connect
threshold=4500
Ticket URL: <http://trac.osgeo.org/grass/ticket/1855&gt;
Priority: critical | Milestone: 6.4.3
Component: Vector | Version: 6.4.3 RCs
Keywords: network | Platform: MSWindows 7
      Cpu: x86-64 |
Changes (by dof1985):
* cc: dof1985 (added)
  * platform: Unspecified => MSWindows 7
  * version: 6.4.2 => 6.4.3 RCs
  * priority: major => critical
Comment:
'''Update:'''
After a long consulation with a generous user from GRASS community, I
still havn't came to a solution. I've tried on two computers with WIN 7 as
operation system, the following GRASS versions: 6.4.2 (through QGIS and
without the plugin), 6.4.3 RCs, 7.0.0
For the first two I have received the same error, for version 7 I didn't
recieve the error but the process have never finished. On the other hand,
my helper managed to complete it in seconds using my files.
Can the problem have something to do with windows 7, some background or
system process, or so? Should I install any extention or plugin in order
to run network analysis programs on win 7?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1855#comment:1&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:1 dof1985]:
any chance to get available your data/location off list to test here it on
my win 7-box?
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1855#comment:2&gt;
      Type: defect | Status: closed
Resolution: wontfix | Keywords: network
  Platform: MSWindows 7 | Cpu: x86-64
Changes (by mmetz):
  * status: new => closed
  * resolution: => wontfix
Comment:
> '''Update:'''
There are currently problems with the database communication in GRASS 7 on
windows. The reported bug does not appear in GRASS 7, but the respective
differences (spatial index) can not be backported for compatibility
reasons.
Closing the ticket as wontfix for GRASS 6.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1855#comment:3&gt;
