#1857: Correction help file r.colors
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Component: Default | Version: svn-trunk
Keywords: | Platform: All
Cpu: Unspecified |
In the help file for r.colors, the following is mentioned:
"The rules color table type will cause r.colors to read color table
specifications from standard input (stdin) and will build the color table
accordingly"
However, this options is not available anymore in GRASS 7.0 (I think).
(There does not seem to be an alternative option to read rules from the
stdin?)
In the help file of r.colors in both GRASS 6.4 and 7.0 there is the line:
“The rules color table type will cause r.colors to read color table specifications from standard input (stdin) and will build the color table accordingly”
In GRASS 6.4 I assume this refers to the option “rules” in the drop down list under “type of color table”. I actually don’t understand the difference between the following two options in GRASS 6.4:
color=rules
rules=-
In GRASS 7.0 the first option does not seem to exist, I don’t see it in the drop down list under “name of color table”. Thus, it seems the “color=rules” option is left out. If that is true (it would make sense to me), the reference to this option (mentioned above) should be removed from the help file.
Paulo
