#1858: inconsistancy g.parser on command console and command line
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Component: Shell Scripts | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: Unspecified |
If you have a script r.test with amongst others the following in the
header:
#%flag
#% key: s
#% description: run r.report on output map?
#% answer : 1
#%END
Opening the GUI interface via the command line will show the flag S unset.
Opening the GUI interface via the command console in the GRASS GIS layer
manager shows the flag S as set (see attached screenshot for
clarification)
Type: defect | Status: closed
Resolution: invalid | Keywords:
Platform: Linux | Cpu: Unspecified
Comment(by glynn):
Replying to [comment:1 martinl]:
> Parser doesn't care about default answer for flags.
It's more accurate to say that the default answer for a flag should always
be zero, as it's impossible to "unset" a flag from the command line.
r54754 modifies g.parser so that "answer" is not a valid parameter for
flags.
