GDAL
January 22, 2013, 9:03pm
1
#1859: d.mon is broken
Reporter: huhabla | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Display | Version: svn-trunk
Keywords: d.mon, wx0 | Platform: Linux
Cpu: x86-64 |
GRASS 7.0.svn (utm43wgs84):~/src/grass7.0 > d.mon wx0
GRASS 7.0.svn (utm43wgs84):~/src/grass7.0 > Traceback (most recent call
last):
File "/home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-
gnu/etc/gui/wxpython/mapdisp/main.py", line 332, in <module>
gmMap = MapApp(0)
File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py",
line 7981, in __init__
self._BootstrapApp()
line 7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
gnu/etc/gui/wxpython/mapdisp/main.py", line 249, in OnInit
size = monSize)
gnu/etc/gui/wxpython/mapdisp/frame.py", line 94, in __init__
self.AddToolbar(toolb)
gnu/etc/gui/wxpython/mapdisp/frame.py", line 377, in AddToolbar
self.toolbars['map'] = MapToolbar(self, self.Map)
gnu/etc/gui/wxpython/mapdisp/toolbars.py", line 90, in __init__
log.WriteCmdLog(_('3D view mode not available'))
UnboundLocalError: local variable 'log' referenced before assignment
Ticket URL: <http://trac.osgeo.org/grass/ticket/1859> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
January 22, 2013, 9:24pm
2
Cpu: x86-64 |
Comment(by wenzeslaus):
It is working for me on Ubuntu 10.04 and 12.04, grass 7 r54755.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1859#comment:1> ;
GDAL
January 22, 2013, 9:38pm
3
Cpu: x86-64 |
Comment(by huhabla):
Besides the fact that it is not working for me on two different Ubuntu
12.04 machines, is this part of code bad style:
gui/wxpython/mapdisp/toolbars.py line 82 - 91
if self.parent.GetLayerManager():
log = self.parent.GetLayerManager().GetLogWindow()
if haveNviz:
choices.append(_('3D view'))
self.toolId['3d'] = 1
else:
from nviz.main import errorMsg
log.WriteWarning(_('Reason: %s') % str(errorMsg))
What happens in case there is no parent with a layer manager? In this case
the application crashes! This exception should be handled, for example to
use a
different log window or the console log?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1859#comment:2> ;
GDAL
January 22, 2013, 9:54pm
4
Cpu: x86-64 |
Replying to [comment:2 huhabla]:
12.04 machines
I don't understand what is your configuration. The error means that you
don't have NVIZ.
case the application crashes! This exception should be handled, for
example to use a
You are completely right! This is subject to ongoing refactoring
(currently paused). This will be fixed, probably, in next days. (Anna will
provide fix for now.)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1859#comment:3> ;
GDAL
June 29, 2013, 10:37am
5
Cpu: x86-64 |
Comment(by neteler):
For me (Fedora 18) it works. Has the code style in question been updated?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1859#comment:4> ;
GDAL
June 30, 2013, 7:15pm
6
Cpu: x86-64 |
Changes (by wenzeslaus):
* priority: critical => normal
Comment:
Replying to [comment:4 neteler]:
To test this properly you need to have GRASS configured without NVIZ
(OpenGL?), I think. It shout be fixed by r54756.
Not yet, file `gui/wxpython/mapdisp/toolbars.py` needs its own large
refactoring and this may be part of it.
Since it is working and the rest is more about refactoring, downgrading
priority.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1859#comment:5> ;
GDAL
March 27, 2014, 12:32am
7
Type: defect | Status: closed
Resolution: fixed | Keywords: d.mon, wx0, nviz
Platform: Linux | Cpu: x86-64
* keywords: d.mon, wx0 => d.mon, wx0, nviz
* status: new => closed
* resolution: => fixed
Comment:
Original error is fixed. Let's not keep this ticket open because the whole
GUI needs a lot of refactoring.
By the way, considering current code, grass interface should be used in
this case for writing error messages.
Reopen if d.mon error complaining about 3D appears again.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1859#comment:6> ;
